What modem should we use for the IMX8MP
We are using a SOM board, model Verdin iMX8M Plus with the Mellow carrier board. We want to use a SIM card to connect to a 4G network. Do you have any recommended 4G LTE modules that are suitable?
Footnote titles and URLs often indicate which version, SDK, or language the content refers to; use them when relevant.
I notice you mentioned using the “Mellow carrier board” with the Verdin iMX8M Plus. However, based on the available documentation, I can find information about the Mallow Carrier Board (1), but I don’t see specific details about 4G LTE module compatibility or recommendations in the sources provided.
The Verdin iMX8M Plus does include PCIe connectivity (1x Single Lane Gen 3) (2)(1), which is commonly used for cellular modules, and the module supports various connectivity options including Wi-Fi and Bluetooth (3)(1).
To provide you with accurate recommendations for 4G LTE modules compatible with your specific setup, I’d need to direct you to more comprehensive resources. You can find detailed compatibility information and recommendations by:
  1. Checking the Verdin iMX8M Plus hardware ecosystem documentation (3)
  2. Reviewing the Mallow Carrier Board specifications for available expansion slots
  3. Exploring the add-ons overview (4) for compatible modules
You may find relevant discussions on the Toradex Community by searching for “4G LTE modules” or “cellular connectivity” with your specific hardware combination.
