what is the expected ppm at 25°C and over the full temperature range of the RTC (Epson RX8130CE) embedded on Toradex Verdin AM62 solo?
I can confirm that the Verdin AM62 Solo features the Epson RX8130CE real-time clock.(1)(2) However, the specific PPM accuracy specifications at 25°C and over the full temperature range are not detailed in the Verdin AM62 datasheets provided.
For detailed electrical specifications including PPM accuracy, I recommend consulting the Epson RX8130CE datasheet directly, which you can find here:
Epson RX8130CE Datasheet(1)(2)
The Epson datasheet will contain the precise frequency accuracy specifications you need, including:
- Typical PPM at 25°C
- PPM variation over the operating temperature range
- Temperature coefficient information
If you need assistance interpreting the RTC specifications in the context of your Verdin AM62 Solo application, feel free to ask.
Hello @Aydin,
As mentioned in the datasheet, at 25 C, the rating is 5 ± 23 ppm (in practice, between -18 and 28 ppm).
For the full temperature range, the application manual lists a variation of -120 to +10 ppm when between -20 C and 70 C, in comparison with the 25 C figure.
A rating is not provided for the full supported range (-40 C to 85 C).
Bruno
