Hi, thanks for the logs. Can you confirm which version of TorizonCore you are using?
If it’s TC5, you should refer to this thread: Weston-vivante:2 launches differently - #2 by jeremias.tx
The screen you should be seeing is the full weston desktop.
However dont see a terminal.
In TC6 it’s currently not possible to launch the terminal directly, but I’ll raise this need internally with the team.
Regards,
