What should the output name in weston.ini be for VGA display on colibri evaluation board with drm-backend? /sys/class/drm has only card0 and card0-DPI-1, so I have tried with name=DPI-1. The display shows terminal output normally.
modetest -M imx-drm fails with “failed to open device ‘imx-drm’: No such file or directory”
journalctl doesn’t help much either:
colibri-imx8x systemd[1]: Starting Weston Wayland Compositor (on tty7)...
colibri-imx8x systemd[1]: Started Weston Wayland Compositor (on tty7).
colibri-imx8x systemd[1]: weston.service: Main process exited, code=exited, status=1/FAILURE
colibri-imx8x systemd[1]: weston.service: Failed with result 'exit-code'.
weston.log:
[09:21:48.044] weston 5.0.0
https://wayland.freedesktop.org
Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
Build: 5.0.0-33-gfb563901-dirty MGS-4627 [#ccc] weston will turn off when panel-psotion=none and use gplay (2019-03-14 11:30:30 +0800)
[09:21:48.045] Command line: /usr/bin/weston --log=/var/log/weston.log
[09:21:48.045] OS: Linux, 4.14.117-3.0.2+ge43e3a26e1b7, #1 SMP PREEMPT Tue Nov 12 08:50:01 UTC 2019, aarch64
[09:21:48.046] Using config file '/etc/xdg/weston/weston.ini'
[09:21:48.049] Output repaint window is 16 ms maximum.
[09:21:48.050] Loading module '/usr/lib/libweston-5/drm-backend.so'
[09:21:48.058] initializing drm backend
[09:21:48.066] logind: session control granted
[09:21:48.071] using /dev/dri/card0
[09:21:48.071] DRM: supports universal planes
[09:21:48.071] DRM: supports atomic modesetting
[09:21:48.071] DRM: does not support picture aspect ratio
[09:21:48.072] Loading module '/usr/lib/libweston-5/gl-renderer.so'
[09:21:48.102] EGL client extensions: EGL_EXT_client_extensions
EGL_EXT_platform_base EGL_KHR_platform_wayland
EGL_EXT_platform_wayland EGL_KHR_platform_gbm
Please let me know if I can provide any other information to help debug this!
I found elsewhere that this might be related to toradex easy installer, and in uboot I set env default -a and saveenv and next boot weston launched normally.
Still modetest fails with imx-drm, though. Same thing with nightly build.
uname -a
Linux colibri-imx8x 4.14.117-3.0.2+ge43e3a26e1b7 #1 SMP PREEMPT Tue Nov 12 08:50:01 UTC 2019 aarch64 GNU/Linux
/etc/issue (this is from custom build, but I tried nightly and release ones from easy installer)
TDX Wayland with XWayland 2.6-snapshot \n \l
Colibri-iMX8X_Console-Image 3.0b2 20191118
It’s just that instead of imx-drm it uses mxsfb-drm which is handling the eLCDIF giving you parallel RGB. And if e.g. using modetest one has to explicitly specify this using -M mxsfb-drm.
Hey,
can confirm, after setting back the u-boot env (after a fresh install with easyinstall) weston starts and gets displayed as it should! Thank you for the hint.
But maybe someone knows which env settings is causing the issue?
