Dear Toradex Support!
In our project, we’d like to use the SHFileOperation function under Wec2013 with Visual Studio 2015, but during the build, there is an error:
*"error LNK2019: unresolved external symbol SHFileOperationW referenced in function "long cdecl WndProc(struct HWND_ ,unsigned int,unsigned int,long)“”
I found the function description on msdn: link, and tells that the ‘ceshell.lib’ is a requirement. I believe this lib is missing from the CE8 2.2 SDK, and that’s cause the linking error.
Can you suggest any solution to resolve this issue? Under WinCE5.0 we used this function, and we’re planning to use under Wec2013 as well, if it’s available. (the msdn site suggest it is.)
Thank you!
