We are testing a design based around the IMX8X colibri board. We have however noticed that ones the system crashes the watchdog timer doesn’t trigger a reboot.
The watchdog timer should be enable they are also under /dev/watchdog yet the system does not restart till we reset it by ourselves. This is happening during EMC tests we expect that the USB is causing the crashing of the system.
