Hi When i am trying to build yocto build for imx8x i get into this error. Has any one seen this error ?
| [ 62%] Generating parameter_validation.cpp
| cd /home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/build/layers && /home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/recipe-sysroot-native/usr/bin/python3-native/python3 /home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/git/scripts/lvl_genvk.py -registry /home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/git/scripts/vk.xml parameter_validation.cpp
| * Building parameter_validation.cpp
| Error: Could not find vk_validation_error_messages.h
| [ 64%] Building CXX object layers/CMakeFiles/VkLayer_parameter_validation.dir/parameter_validation.cpp.o
| cd /home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/build/layers && /home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/recipe-sysroot-native/usr/bin/aarch64-poky-linux/aarch64-poky-linux-g++ -DAPI_NAME=\"Vulkan\" -DFALLBACK_CONFIG_DIRS=\"/etc/xdg\" -DFALLBACK_DATA_DIRS=\"/usr/local/share:/usr/share\" -DSYSCONFDIR=\"/etc\" -DVK_USE_PLATFORM_WAYLAND_KHR -DVK_USE_PLATFORM_WAYLAND_KHX -DVkLayer_parameter_validation_EXPORTS -I/home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/recipe-sysroot/usr/include -I/home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/git/include -I/home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/git/layers -I/home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/git/layers/../loader -I/home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/git/layers/../include/vulkan -I/home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/build/layers -I/home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/build --sysroot=/home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0=/usr/src/debug/vulkan/1.0.65.2-r0 -fdebug-prefix-map=/home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/recipe-sysroot= -fdebug-prefix-map=/home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/recipe-sysroot-native= -fvisibility-inlines-hidden --sysroot=/home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/recipe-sysroot -Wall -Wextra -Wno-unused-parameter -Wno-missing-field-initializers -fno-strict-aliasing -fno-builtin-memcmp -Wimplicit-fallthrough=0 -std=c++11 -fno-rtti -fvisibility=hidden -Wpointer-arith -Wno-unused-function -Wno-sign-compare -fPIC -o CMakeFiles/VkLayer_parameter_validation.dir/parameter_validation.cpp.o -c /home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/build/layers/parameter_validation.cpp
| aarch64-poky-linux-g++: error: /home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/build/layers/parameter_validation.cpp: No such file or directory
| aarch64-poky-linux-g++: fatal error: no input files
| compilation terminated.
| layers/CMakeFiles/VkLayer_parameter_validation.dir/build.make:73: recipe for target 'layers/CMakeFiles/VkLayer_parameter_validation.dir/parameter_validation.cpp.o' failed
| make[2]: *** [layers/CMakeFiles/VkLayer_parameter_validation.dir/parameter_validation.cpp.o] Error 1
| make[2]: Leaving directory '/home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/build'
| CMakeFiles/Makefile2:571: recipe for target 'layers/CMakeFiles/VkLayer_parameter_validation.dir/all' failed
| make[1]: *** [layers/CMakeFiles/VkLayer_parameter_validation.dir/all] Error 2
| make[1]: Leaving directory '/home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/build'
| Makefile:132: recipe for target 'all' failed
| make: *** [all] Error 2
| WARNING: exit code 2 from a shell command.
| ERROR: Function failed: do_compile (log file is located at /home/osboxes/imx/build/tmp/work/aarch64-mx8-poky-linux/vulkan/1.0.65.2-r0/temp/log.do_compile.12878)
ERROR: Task (/home/osboxes/imx/sources/poky/meta/recipes-graphics/vulkan/vulkan_1.0.65.2.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1711 tasks of which 1704 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Sistla.
My build environment is ubuntu 16.04
machine is colibri-imx8xqxp
