VS Code IDE Extension Issue Report
OS: linux :: x64
Distro: Ubuntu 22.04.2 LTS
Extension activation logs:
[11-14 10:56:54.573] Activating Torizon IDE ...
[11-14 10:56:54.578] Resolving host IP address ...
[11-14 10:56:56.278] Host IP address OK
[11-14 10:56:56.593] Docker installed OK
[11-14 10:56:58.394] ERROR :: Docker is not running. Please start the Docker runtime daemon
[11-14 10:57:00.685] Docker compose OK
[11-14 10:57:01.099] PowerShell OK
[11-14 10:57:01.285] git OK
[11-14 10:57:01.814] dig OK
[11-14 10:57:02.442] avahi-resolve OK
[11-14 10:57:02.556] nmap OK
[11-14 10:57:03.560] iputils-ping OK
[11-14 10:57:04.255] file OK
[11-14 10:57:05.028] sshpass OK
[11-14 10:57:05.293] net-tools OK
[11-14 10:57:05.297] Cloning project templates
[11-14 10:57:05.440] Project templates clone OK
[11-14 10:57:05.996] Checkout templates repo to dev OK
[11-14 10:57:07.084] Project templates updated
[11-14 10:57:07.099] Checking connected devices ...
[11-14 10:57:07.111] Scanning Torizon devices ...
[11-14 10:57:07.218] Configuring debug id_rsa ...
[11-14 10:57:07.222] Debug id_rsa OK
[11-14 10:57:07.226] ERROR :: Errors during the initialization of Torizon IDE Extension.
[11-14 10:57:07.230] HOUSTON WE HAVE A PROBLEM!
[11-14 10:57:07.234] PLEASE READ THE LOGS!
[11-14 10:57:08.833] WARNING :: Device not reached! Please check if the device is turned on and connected to the network.
[11-14 10:57:08.837] ERROR :: verdin-imx8mp-14773125.local not reached
[11-14 10:57:14.277] Debian bookworm packages list load OK
[11-14 10:58:05.465] ERROR :: validate-deps-running failed with exit code 69
Tasks logs:
 *  Executing task: pwsh .conf/validateDepsRunning.ps1
儭 VALIDATING ENVIRONMENT
 Docker is not running!
儭  Please start Docker
儭  Please make sure to reload the VS Code window after starting Docker
 *  The terminal process "pwsh '.conf/validateDepsRunning.ps1'" terminated with exit code: 69.
As the logs are telling us, Docker is not running. Please check if you have Docker installed and running.
Set up the Torizon IDE Extension 2 Environment | Toradex Developer Center
