I have been following this guide: Build and Run Your First Python Application
I am currently developing for a IMX6DL v1.1A, Aster carrier board v1.1B, on a Ubuntu 20.04 PC.
However, when I reach step 9 of the guide and press F5, VS Code throws me this error:
The terminal output is as follows:
The device seems to be properly connected. Indeed, I can access it through the SSH terminal normally.
It seems to me it’s as if the Torizon extension couldn’t properly configure the ‘preLaunchTask’. However, searching on this forum, I read that one shouldn’t have to manually configure anything. Furthermore, it seems to identify a different board than the one I’m using (Colibri Evaluation Board and not the Aster).
How should I proceed?
