I’m evaluation the Colibri iMX8DX 1GB with the goal to migrate our C# application currently running on a Colibri T30 with WinCE. I loaded VSCode with the new AppoloX extension.
This is more a bug report than a question:
I installed WSL2 and Ubuntu 22.04.1 to evaluate our new module using your new VSCode extension. I followed the docs (GitHub - toradex/torizon-experimental-torizon-ide-v2-docs: VS Code Torizon Integrated Development Environment Documentation) but did not see the UAC prompt that should follow the run-share-wsl-ports
task.
Since there is an accumulation of terminals we don’t see it right away that something failed, however a terminal shows:
/usr/bin/bash: line 1: ifconfig: command not found
Found out that ifconfig is not installed in this Ubuntu version. I had to sudo apt install net-tools
and then re-run the task manually.
