Vpn or ftps transfer via ethernet
Hello Toradex Team,
with the Colibri T30 we need secure data transmission via Ethernet. I was thinking of VPN or FTPS.
Would you have a chance here? We would also be willing to pay for development costs.
Would be very nice if you could offer a solution for this.
Best regards
Saphymo
Hello @Saphymo ,
VPN
Check the following developer website, where we have documented the different options.
SFTP
There was recently a community question about this topic, please check the following community issue.
Hello Toradex Team,
thanks for answer.
I used the following link:
I noticed a completely inexplicable behavior:
If I am in the same subnet as the VPN server (which makes no sense) the VPN connection (L2TP) works perfectly.
When I try to connect from another network, it does not work anymore.
I tried the different networks and in the end I can`t make a VPN connection.
A comparison computer can establish a VPN connection in the same network with the same IP.
Do you have any idea what the reason could be?
For me, this is a behavior that could not occur…
Best regards
Saphymo
