Visual Code Studio and Torizon extension
Hi
Platform: Windows 10
Visual code:
Version: 1.84.2 (user setup)
Commit: 1a5daa3a0231a0fbba4f14db7ec463cf99d7768e
Date: 2023-11-09T10:51:52.184Z
Electron: 25.9.2
ElectronBuildId: 24603566
Chromium: 114.0.5735.289
Node.js: 18.15.0
V8: 11.4.183.29-electron.0
OS: Windows_NT x64 10.0.19045
When I search for the Torizon plugin I get the message that is attached.
As I can see in the documentation X64 should be supported.
Any idea why I see this message and what could I do about it?
Hi, I had the same problem, toradex recommends to use ubuntu instead :frowning: wsl works well
Thanks for the reply but I agree with you it is not a solution
Hi @epoulsen ,
The message you saw is expected: On Windows the IDE Extension 2 can only be installed if VSCode is connected to WSL2.
You can take a look at this article on how to setup the extension environment on Windows:
Lucas Akira
