in display driver registry there is a setting for VideoMemSize.
What setting is recommended ?
What is this setting good for ?
For 16Bit-SVGA I would need 8006002 bytes ? Is this sufficient or would you recommend more ?
Is videoram used when CreateCompatibleDC/CreateCompatibleBitmap is called ?
There are some remarks regarding videoram (VideoRAM | Toradex Developer Center) but this obviously is not for imx6.
What exact hardware and software versions of things are you talking about?
@Frax222,
Could you please wait till Monday? The developer is on vacation, we will get back you in early next week.
Thank you.
no problem - it is not urgent.
Video memory is not used only for the main frame buffer, is used also to store bitmap and back-buffers. If you don’t use DirectDraw, overlays, video playback or animations, with a 800x600x16bpp screen you can reserve 4-8MB for that.
