Thank you both! I will try this and let you know. I’m hoping for real-time as I’m not planning to save the file at this point and from what I understood in the NXP thread, the I/O is the biggest time sink for them.
Going down the path of building a device tree overlay to test the solution, as that seemed the simplest way. However running into issues building the standard device tree overlays from the Git branch. I’ve created a separate thread to not mix up the two problems.
