What do I need to do to enable the VGA port? HDMI works, but then I want to switch to VGA as HDMI “steals” the audio.
What module and which BSP (e.g. Linux/WEC) are you using?
WinCE 7, T30
VGA port is enabled by default on WinCE. If I get you correct your main issue is, that you are missing audio in case you attach HDMI. This can be prevented by using the key HDMIAudioOff. You get more information on that here.
In case you still want to use HDMI, make sure you once boot without having VGA attached. In case you don’ t have any output on the screen, your screen may have issues with the default 640x480 resolution?
