Vf61 linux wifi
I am having Colivri Vf61 with linux image ver 2.6
I also have a USB Wifi module LM006-1004 which has rtl8192cu chipset
How to proceed so that i can use the wifi module?
Please share guidelines
Thanks and Regards,
LM006 support is available out-of-the-box on our pre-build Linux images since v2.5Beta3. Refer this article for information related to WiFi connection bring up.
But,
connmanctl enable wifi shows following error
Error wifi: Method “SetProperty” with signature “sv” on interface "net.connman.t
Besides when i insert wifi module to usb only following line appears. No Driver details are shown
[ 731.584138] usb 2-1.1: new high-speed USB device number 9 using ci_hdrc
Can you provide output of ‘dmesg’ and ‘lsmod’ ?
[ 0.000000] Linux version 4.4.21-dirty (aneesh@aneesh-Inspiron-5559) (gcc 6
[ 0.000000] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruce
[ 0.000000] Machine model: Toradex Colibri VF61 on Colibri Evaluation Board
[ 0.000000] cma: Reserved 16 MiB at 0x8ec00000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 65024
[ 0.000000] free_area_init_node: node 0, pgdat 808777ac, node_mem_map 8ea00
[ 0.000000] Normal zone: 508 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 65024 pages, LIFO batch:15
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total 6
[ 0.000000] Kernel command line: ubi.mtd=ubi root=ubi0:rootfs rootfstype=u0
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 232440K/260096K available (6079K kernel code, 216K rwd)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0x90000000 - 0xff800000 (1784 MB)
[ 0.000000] lowmem : 0x80000000 - 0x8fe00000 ( 254 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80808034 (8193 kB)
[ 0.000000] .init : 0x80809000 - 0x80842000 ( 228 kB)
[ 0.000000] .data : 0x80842000 - 0x80878280 ( 217 kB)
[ 0.000000] .bss : 0x80878280 - 0x808a43b8 ( 177 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] L2C-310 erratum 769419 enabled
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 8 ways, 512 kB
[ 0.000000] L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x06060000
[ 0.000039] sched_clock: 64 bits at 166MHz, resolution 5ns, wraps every 43s
[ 0.000090] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cys
[ 0.001038] Console: colour dummy device 80x30
[ 0.002048] console [tty1] enabled
[ 0.002107] Calibrating delay loop… 331.77 BogoMIPS (lpj=1658880)
[ 0.060146] pid_max: default: 32768 minimum: 301
[ 0.060363] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.060425] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 byte)
[ 0.061687] CPU: Testing write buffer coherency: ok
[ 0.062280] Setting up static identity map for 0x80008200 - 0x80008258
[ 0.064321] devtmpfs: initialized
[ 0.077154] VFP support v0.3: implementor 41 architecture 2 part 30 varian1
[ 0.077793] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff,s
[ 0.079628] pinctrl core: initialized pinctrl subsystem
[ 0.081761] NET: Registered protocol family 16
[ 0.084421] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.085831] cpuidle: using governor menu
[ 0.108379] PM: No CKE/RESET pulls, disable Suspend-to-RAM
[ 0.109064] hw-breakpoint: found 2 (+1 reserved) breakpoint and 1 watchpoi.
[ 0.109154] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.109868] vf610-pinctrl 40048000.iomuxc: initialized IMX pinctrl driver
[ 0.137965] SCSI subsystem initialized
[ 0.138547] usbcore: registered new interface driver usbfs
[ 0.138735] usbcore: registered new interface driver hub
[ 0.138932] usbcore: registered new device driver usb
[ 0.140407] i2c i2c-0: IMX I2C adapter registered
[ 0.140542] i2c i2c-0: using dma0chan0 (tx) and dma0chan1 (rx) for DMA tras
[ 0.140856] Linux video capture interface: v2.00
[ 0.141041] pps_core: LinuxPPS API ver. 1 registered
[ 0.141095] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Gi>
[ 0.141223] PTP clock support registered
[ 0.142021] Advanced Linux Sound Architecture Driver Initialized.
[ 0.144084] clocksource: Switched to clocksource arm_global_timer
[ 0.161472] NET: Registered protocol family 2
[ 0.162893] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.163007] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.163104] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.163349] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.163429] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.163736] NET: Registered protocol family 1
[ 0.164352] RPC: Registered named UNIX socket transport module.
[ 0.164418] RPC: Registered udp transport module.
[ 0.164466] RPC: Registered tcp transport module.
[ 0.164514] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.166217] hw perfevents: enabled with armv7_cortex_a5 PMU driver, 3 coune
[ 0.167941] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.183087] NFS: Registering the id_resolver key type
[ 0.183231] Key type id_resolver registered
[ 0.183284] Key type id_legacy registered
[ 0.183364] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.184371] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.185242] fuse init (API version 7.23)
[ 0.189312] io scheduler noop registered
[ 0.189386] io scheduler deadline registered
[ 0.189725] io scheduler cfq registered (default)
[ 0.198232] 40027000.serial: ttyLP0 at MMIO 0x40027000 (irq = 19, base_bauT
[ 0.719166] console [ttyLP0] enabled
[ 0.723618] 40028000.serial: ttyLP1 at MMIO 0x40028000 (irq = 20, base_bauT
[ 0.733915] 40029000.serial: ttyLP2 at MMIO 0x40029000 (irq = 21, base_bauT
[ 0.744988] [drm] Initialized drm 1.1.0 20060810
[ 0.756792] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.763464] [drm] No driver support for vblank timestamp query.
[ 0.813900] Console: switching to colour frame buffer device 100x30
[ 0.844531] fsl-dcu 40058000.dcu: fb0: frame buffer device
[ 0.858827] [drm] Initialized fsl-dcu-drm 1.0.0 20150213 on minor 0
[ 0.885962] loop: module loaded
[ 0.900360] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xdc
[ 0.915352] nand: Macronix MX30LF4G28AB
[ 0.927572] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB 2
[ 0.944311] Bad block table found at page 262080, version 0x01
[ 0.959243] Bad block table found at page 262016, version 0x01
[ 0.974134] 4 ofpart partitions found on MTD device vf610_nfc
[ 0.988486] Creating 4 MTD partitions on “vf610_nfc”:
[ 1.002214] 0x000000000000-0x000000020000 : “vf-bcb”
[ 1.016648] 0x000000020000-0x000000180000 : “u-boot”
[ 1.030974] 0x000000180000-0x000000200000 : “u-boot-env”
[ 1.045606] 0x000000200000-0x000020000000 : “ubi”
[ 1.063626] spidev spi1.0: buggy DT: spidev listed directly in DT
[ 1.078117] ------------[ cut here ]------------
[ 1.091075] WARNING: CPU: 0 PID: 1 at drivers/spi/spidev.c:720 spidev_prob)
[ 1.107883] Modules linked in:
[ 1.119318] CPU: 0 PID: 1 Comm: swapper Not tainted 4.4.21-dirty #9
[ 1.134023] Hardware name: Freescale Vybrid VF5xx/VF6xx (Device Tree)
[ 1.148835] Backtrace:
[ 1.159497] [<80013474>] (dump_backtrace) from [<8001366c>] (show_stack+0x)
[ 1.175702] r7:803b3880 r6:000002d0 r5:00000009 r4:00000000
[ 1.190141] [<80013654>] (show_stack) from [<802a0d8c>] (dump_stack+0x24/0)
[ 1.206163] [<802a0d68>] (dump_stack) from [<80021b70>] (warn_slowpath_com)
[ 1.223077] [<80021ae8>] (warn_slowpath_common) from [<80021c40>] (warn_sl)
[ 1.240815] r8:00000000 r7:80863bd8 r6:80863bc8 r5:8e726800 r4:8e726800
[ 1.256742] [<80021c1c>] (warn_slowpath_null) from [<803b3880>] (spidev_pr)
[ 1.274288] [<803b36d8>] (spidev_probe) from [<803b13b4>] (spi_drv_probe+0)
[ 1.291295] r8:00000000 r7:80863bd8 r6:80863bc8 r5:00000000 r4:8e726800
[ 1.307584] [<803b1330>] (spi_drv_probe) from [<80355a84>] (driver_probe_d)
[ 1.325553] r7:80863bd8 r6:00000000 r5:8e726800 r4:808998b0
[ 1.341164] [<80355880>] (driver_probe_device) from [<80355c9c>] (__device)
[ 1.370215] r9:00000000 r8:8089988c r7:00000001 r6:8e726800 r5:8e44bc48 r8
[ 1.388806] [<80355c10>] (__device_attach_driver) from [<80353dc0>] (bus_f)
[ 1.408673] r7:00000001 r6:80355c10 r5:8e44bc48 r4:00000000
[ 1.425816] [<80353d58>] (bus_for_each_drv) from [<803557d8>] (__device_at)
[ 1.445916] r6:8e726834 r5:8e726800 r4:8e726800
[ 1.462382] [<80355720>] (_device_attach) from [<80355d10>] (device_initi)
[ 1.483068] r7:00000000 r6:80863684 r5:8e726800 r4:8e726808
[ 1.500918] [<80355cfc>] (device_initial_probe) from [<80354cec>] (bus_pro)
[ 1.521769] [<80354c60>] (bus_probe_device) from [<80352e5c>] (device_add+)
[ 1.541977] r7:00000000 r6:8e726400 r5:8e726800 r4:8e726808
[ 1.560051] [<80352ae4>] (device_add) from [<803b1ad4>] (spi_add_device+0x)
[ 1.580156] r10:807a1554 r9:807a1560 r8:807589b8 r7:8e4c2610 r6:8e726400 0
[ 1.600676] r4:8e726800
[ 1.615339] [<803b1a34>] (spi_add_device) from [<803b3134>] (spi_register
[ 1.636460] r7:8fde3a18 r6:8e726400 r5:00000000 r4:8e726800
[ 1.654871] [<803b2c7c>] (spi_register_master) from [<803b5bcc>] (dspi_pro)
[ 1.675820] r10:00000002 r9:8e4c2610 r8:8e719590 r7:8e4c2610 r6:8e7266a0 0
[ 1.696549] r4:8e726400
[ 1.711410] [<803b5744>] (dspi_probe) from [<803574d4>] (platform_drv_prob)
[ 1.732005] r10:00000000 r9:00000007 r8:00000000 r7:fffffdfb r6:80863c2c 0
[ 1.752758] r4:808998b0
[ 1.767612] [<80357480>] (platform_drv_probe) from [<80355a84>] (driver_pr)
[ 1.789205] r7:80863c2c r6:00000000 r5:8e4c2610 r4:808998b0
[ 1.807560] [<80355880>] (driver_probe_device) from [<80355c0c>] (__driver)
[ 1.828632] r9:00000007 r8:80878280 r7:00000000 r6:8e4c2644 r5:80863c2c r0
[ 1.849227] [<80355b78>] (__driver_attach) from [<80353d00>] (bus_for_each)
[ 1.869999] r7:00000000 r6:80355b78 r5:80863c2c r4:00000000
[ 1.888215] [<80353c90>] (bus_for_each_dev) from [<80355370>] (driver_atta)
[ 1.908731] r6:8085bab0 r5:8e719380 r4:80863c2c
[ 1.925752] [<8035534c>] (driver_attach) from [<80354fa8>] (bus_add_driver)
[ 1.946250] [<80354e00>] (bus_add_driver) from [<8035638c>] (driver_regist)
[ 1.966731] r7:8e718640 r6:808481a0 r5:808224fc r4:80863c2c
[ 1.984755] [<8035630c>] (driver_register) from [<803573fc>] (_platform_d)
[ 2.018197] r5:808224fc r4:808481a0
[ 2.033838] [<803573b4>] (platform_driver_register) from [<80822518>] (f)
[ 2.067704] [<808224fc>] (fsl_dspi_driver_init) from [<80009614>] (do_one
[ 2.088950] [<8000957c>] (do_one_initcall) from [<80809e64>] (kernel_init
[ 2.110212] r10:80834838 r9:00000007 r8:80878280 r7:80834830 r6:80878280 8
[ 2.130820] r4:80806178
[ 2.145547] [<80809d1c>] (kernel_init_freeable) from [<805f2cb8>] (kernel
[ 2.166298] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 8
[ 2.186889] r4:00000000
[ 2.201594] [<805f2ca8>] (kernel_init) from [<8000f7f8>] (ret_from_fork+0x)
[ 2.221660] r5:805f2ca8 r4:00000000
[ 2.237501] —[ end trace 51f770b07185e194 ]—
[ 2.256736] +V3.3: supplied by 3.3V
[ 2.272740] pps pps0: new PPS source ptp0
[ 2.293929] libphy: fec_enet_mii_bus: probed
[ 2.310389] fec 400d1000.ethernet eth0: registered PHC device 0
[ 2.327948] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.345966] usbcore: registered new interface driver usb-storage
[ 2.363093] usbcore: registered new interface driver usbserial
[ 2.379478] usbcore: registered new interface driver usbserial_generic
[ 2.396313] usbserial: USB Serial support registered for generic
[ 2.412428] usbcore: registered new interface driver ftdi_sio
[ 2.428088] usbserial: USB Serial support registered for FTDI USB Serial De
[ 2.445224] usbcore: registered new interface driver pl2303
[ 2.460654] usbserial: USB Serial support registered for pl2303
[ 2.478532] 40034000.usb supply vbus not found, using dummy regulator
[ 2.495803] mousedev: PS/2 mouse device common for all mice
[ 2.512562] rtc-ds1307 0-0068: rtc core: registered m41t00 as rtc0
[ 2.528955] snvs_rtc 400a7000.snvs:snvs-rtc-lp: rtc core: registered 400a71
[ 2.547168] i2c /dev entries driver
[ 2.562020] imx2-wdt 4003e000.wdog: timeout 60 sec (nowayout=0)
[ 2.577222] sdhci: Secure Digital Host Controller Interface driver
[ 2.592272] sdhci: Copyright(c) Pierre Ossman
[ 2.605299] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.620488] /soc/aips-bus@40080000/esdhc@400b2000: voltage-ranges unspecifd
[ 2.636374] sdhci-esdhc-imx 400b2000.esdhc: Got CD GPIO
[ 2.650562] sdhci-esdhc-imx 400b2000.esdhc: No vmmc regulator found
[ 2.665527] sdhci-esdhc-imx 400b2000.esdhc: No vqmmc regulator found
[ 2.714303] mmc0: SDHCI controller on 400b2000.esdhc [400b2000.esdhc] usinA
[ 2.732648] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.747228] usbcore: registered new interface driver usbhid
[ 2.761599] usbhid: USB HID core driver
[ 2.825332] wm97xx-ts 0-0:wm9712-codec: detected a wm9712 codec
[ 2.842732] input: wm97xx touchscreen as /devices/platform/sound/0-0:wm9710
[ 2.863815] fsl-sai-ac97-dt-driver sound: wm9712-hifi <-> 40031000.sai mapk
[ 2.885303] Netfilter messages via NETLINK v0.30.
[ 2.899740] nfnl_acct: registering with nfnetlink.
[ 2.914071] nf_conntrack version 0.5.0 (3887 buckets, 15548 max)
[ 2.930544] nf_tables: (c) 2007-2009 Patrick McHardy
[ 2.947562] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.963514] NET: Registered protocol family 10
[ 2.979207] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.993951] sit: IPv6 over IPv4 tunneling driver
[ 3.008933] NET: Registered protocol family 17
[ 3.022262] bridge: automatic filtering via arp/ip/ip6tables has been depr.
[ 3.053178] Bridge firewalling registered
[ 3.066396] 8021q: 802.1Q VLAN Support v1.8
[ 3.079684] Key type dns_resolver registered
[ 3.093093] Registering SWP/SWPB emulation handler
[ 3.107851] registered taskstats version 1
[ 3.124909] 40034000.usb supply vbus not found, using dummy regulator
[ 3.145447] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 3.159309] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number1
[ 3.194136] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 3.209958] hub 1-0:1.0: USB hub found
[ 3.222487] hub 1-0:1.0: 1 port detected
[ 3.236283] VCC_USB[1-4]: supplied by 5V
[ 3.252468] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 3.265406] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number2
[ 3.294121] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 3.308857] hub 2-0:1.0: USB hub found
[ 3.320441] hub 2-0:1.0: 1 port detected
[ 3.333871] ubi0: default fastmap pool size: 200
[ 3.346119] ubi0: default fastmap WL pool size: 100
[ 3.358427] ubi0: attaching mtd3
[ 3.583992] ubi0: attached by fastmap
[ 3.594913] ubi0: fastmap pool size: 200
[ 3.605880] ubi0: fastmap WL pool size: 100
[ 3.630740] ubi0: attached mtd3 (name “ubi”, size 510 MiB)
[ 3.642831] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 3.656347] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 3.669927] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 3.683830] ubi0: good PEBs: 4076, bad PEBs: 4, corrupted PEBs: 0
[ 3.696902] ubi0: user volume: 3, internal volumes: 1, max. volumes count:8
[ 3.711333] ubi0: max/mean erase counter: 53/13, WL threshold: 4096, image0
[ 3.727299] ubi0: available PEBs: 0, total reserved PEBs: 4076, PEBs reser6
[ 3.751422] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 3.765708] ubi0: background thread “ubi_bgt0d” started, PID 58
[ 3.781460] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 3.797967] rtc-ds1307 0-0068: setting system clock to 2000-01-01 00:39:50)
[ 3.829302] ALSA device list:
[ 3.840858] #0: Colibri VF61 AC97 Audio
[ 3.878141] UBIFS (ubi0:2): recovery needed
[ 3.936360] hub 2-1:1.0: USB hub found
[ 3.948709] hub 2-1:1.0: 4 ports detected
[ 4.116331] UBIFS (ubi0:2): recovery deferred
[ 4.129213] UBIFS (ubi0:2): UBIFS: mounted UBI device 0, volume 2, name "re
[ 4.146294] UBIFS (ubi0:2): LEB size: 126976 bytes (124 KiB), min./max. I/s
[ 4.174126] UBIFS (ubi0:2): FS size: 496984064 bytes (473 MiB, 3914 LEBs),)
[ 4.204400] UBIFS (ubi0:2): reserved for root: 0 bytes (0 KiB)
[ 4.220417] UBIFS (ubi0:2): media format: w4/r0 (latest is w4/r0), UUID 8Fl
[ 4.253100] VFS: Mounted root (ubifs filesystem) readonly on device 0:14.
[ 4.271383] devtmpfs: mounted
[ 4.285758] Freeing unused kernel memory: 228K (80809000 - 80842000)
[ 4.324200] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[ 4.495274] random: systemd: uninitialized urandom read (16 bytes read, 60)
[ 4.539048] systemd[1]: systemd 226 running in system mode. (+PAM -AUDIT -)
[ 4.589673] usb 2-1.3: new low-speed USB device number 4 using ci_hdrc
[ 4.608647] systemd[1]: Detected architecture arm.
[ 4.645918] systemd[1]: Set hostname to .
[ 4.700243] random: systemd: uninitialized urandom read (16 bytes read, 64)
[ 4.778132] input: Logitech USB Optical Mouse as /devices/platform/soc/soc2
[ 4.846427] hid-generic 0003:046D:C05A.0001: input,hidraw0: USB HID v1.11 0
[ 4.948615] random: systemd-sysv-ge: uninitialized urandom read (16 bytes )
[ 4.999212] random: systemd-sysv-ge: uninitialized urandom read (16 bytes )
[ 5.067884] random: systemd: uninitialized urandom read (16 bytes read, 72)
[ 5.103476] random: systemd: uninitialized urandom read (16 bytes read, 72)
[ 5.179938] random: systemd: uninitialized urandom read (16 bytes read, 76)
[ 5.216012] usb 2-1.4: new low-speed USB device number 5 using ci_hdrc
[ 5.236968] random: systemd: uninitialized urandom read (16 bytes read, 77)
[ 5.274653] random: systemd: uninitialized urandom read (16 bytes read, 77)
[ 5.355200] random: systemd: uninitialized urandom read (16 bytes read, 80)
[ 5.432878] input: USB USB Keykoard as /devices/platform/soc/soc:aips-bus@3
[ 5.535681] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 0
[ 5.587955] input: USB USB Keykoard as /devices/platform/soc/soc:aips-bus@4
[ 5.684962] hid-generic 0003:1C4F:0002.0003: input,hidraw2: USB HID v1.10 1
[ 5.837410] systemd[1]: Started Dispatch Password Requests to Console Dire.
[ 5.887815] systemd[1]: Listening on networkd rtnetlink socket.
[ 5.924696] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.965380] systemd[1]: Created slice System Slice.
[ 6.004872] systemd[1]: Created slice system-getty.slice.
[ 6.044606] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.084627] systemd[1]: Created slice User and Session Slice.
[ 6.124742] systemd[1]: Started Forward Password Requests to Wall Director.
[ 6.164343] systemd[1]: Reached target Paths.
[ 6.204691] systemd[1]: Listening on Journal Socket.
[ 6.251309] systemd[1]: Starting Load Kernel Modules…
[ 6.297296] systemd[1]: Starting (null)…
[ 6.337873] systemd[1]: Starting Setup Virtual Console…
[ 6.387885] systemd[1]: Mounting Debug File System…
[ 6.420541] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.516361] systemd[1]: Starting Journal Service…
[ 6.544915] systemd[1]: Reached target Slices.
[ 6.584756] systemd[1]: Reached target Swap.
[ 6.618174] systemd[1]: Mounting Temporary Directory…
[ 6.661803] systemd[1]: Starting File System Check on Root Device…
[ 6.721258] systemd[1]: Listening on udev Kernel Socket.
[ 6.764986] systemd[1]: Listening on udev Control Socket.
[ 6.826676] systemd[1]: Set up automount Arbitrary Executable File Formats.
[ 6.909635] systemd[1]: Mounted Debug File System.
[ 6.964674] systemd[1]: Mounted Temporary Directory.
[ 6.996016] systemd[1]: Started Journal Service.
[ 7.406970] UBIFS (ubi0:2): completing deferred recovery
[ 7.579018] UBIFS (ubi0:2): background thread “ubifs_bgt0_2” started, PID 3
[ 7.606848] UBIFS (ubi0:2): deferred recovery completed
[ 7.936427] systemd-journald[77]: Received request to flush runtime journa1
[ 7.994376] systemd-journald[77]: File /var/log/journal/19569021af1d48fe85.
[ 8.407221] random: nonblocking pool is initialized
[ 12.157545] wm97xx-ts 0-0:wm9712-codec: No IRQ specified
[ 15.684218] fec 400d1000.ethernet eth0: Freescale FEC PHY driver [Micrel K)
[ 15.759825] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.009838] wm97xx-ts 0-0:wm9712-codec: No IRQ specified
[ 17.684986] fec 400d1000.ethernet eth0: Link is Up - 100Mbps/Full - flow cx
[ 17.693065] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 356.563729] usb 2-1.1: USB disconnect, device number 3
[ 363.714139] usb 2-1.1: new high-speed USB device number 6 using ci_hdrc
[ 456.147602] usb 2-1.3: USB disconnect, device number 4
[ 458.684141] usb 2-1.3: new low-speed USB device number 7 using ci_hdrc
[ 458.834364] input: Logitech USB Optical Mouse as /devices/platform/soc/soc5
[ 458.853918] hid-generic 0003:046D:C05A.0004: input,hidraw0: USB HID v1.11 0
[ 717.267726] usb 2-1.1: USB disconnect, device number 6
[ 721.084138] usb 2-1.1: new high-speed USB device number 8 using ci_hdrc
[ 727.763720] usb 2-1.1: USB disconnect, device number 8
[ 1551.315716] usb 2-1.1: USB disconnect, device number 9
[ 3265.214112] usb 2-1.1: new high-speed USB device number 10 using ci_hdrc
lsmod shows no details
Module Size Used by
Seems you have a custom kernel loaded did you also build the kernel modules and deploy them? Please refer this article for information/hints on deploying the kernel modules.
Yes I am using custom kernel but i enabled rtl8192cu when kernel configuring
using make nconfig. Should i do something more
As mentioned in my earlier comment you will also need to build and deploy the kernel modules.
Thank you its working good
