we plan to implement a project with means of the Colibri VF61 dual core communication via MCC2. Due to the fact that the original Linux Kernel 3.13 shipped with TRW65 (from TimeSys) is quite obsolete we would prefer to use the actual Linux kernel 4.1 from Toradex. On the M4 side we would like to use MQX (4.2.0), for the inter-core communication MCC2 shall be used. I have read the article about “MQX on the Cortex-M4 of a Colibri VF61” but unfortunately this example does not address MCC2 inter-core communication.
Have anyone experience with implementing MCC2 in Toradex Linux Kernel 4.1 and MQX?
Any doubts that this may be a hard way to get it work, especially on the Linux side due to a lot of changes from Kernel 3.13 to 4.1?
Another question which MCC and kernel has Toradex used in their example in article “Ping-Pong Example Between Linux and eCos RTOS on Colibri VF61”? Does the MCC implementation of that Linux image will also work with MQX?
Since MCCv2 still exports the API to userspace, there is still userspace library required. Up until recently that library was only available under the GPL v2 license (Timesys/Freescale just recently changed that, so that argument actually no longer holds true)/
Therefor we decided not to adopt MCCv2. However, I think it should be viable to forward-port the MCCv2 implement with a reasonable amount of effort. We currently exploring to implement rpmsg for Vybrid which looks like the more future proof solution.
The MCCv1 implementation we use is ABI compatible with MQX, hence the Ping-Pong Example works also with MQX (I think it was 4.1.2 which implements the MCCv1 API).
Hi @stefan.agner this means that if I need communication between A5 (Linux 4.1 from Toradex ) and M4 (Freescale MQX) the version of MQX can not be 4.2. Is this correct?
@danieloak, that is right. I think the differences between MCCv1 and MCCv2 are really minimal. The underlying protocol might even be the same, so maybe it just works by incrementing the version number on Linux side. Otherwise, probably diffing the differences in the MCC implementation between MQX 4.1.2 and 4.2 and backport MCCv1 to MQX 4.2 might be work as well.
I don’t currently have a form which I can distribute to you. I basically took an MQX version with MCCv1 and copied the MCC folder into MQX 4.2.0. Stefan may still have a copy of the work I did for it.
Hi @stefan.agner thank you for your explanation and the provided download. In reference to your tarball MQX-4.2.0_with_MCC_backported_1.2.tar.gz the pingpong example is working fine with VF61 Toradex Linux Image 2.5 (Kernel 4.1).
Thanks Torsten
I started from mcc_v1.2. Symlinked it with mcc.
Did the code change as you.
Found that post-build was failing. Needed to add:
cd mcc/source/include/mqx && ln -s …/mcc_config.h.
(Strange, the post-build script is identical to mcc 2.1…)
