I have done the porting of an application from PXA to VF61,
My application runs correctly but after 4 hours it crashed.
In my opinion the problem depends on the SODIMM 137 set to high.
In order to investigate this problem.
I downloaded from toradex site the image WinCe6.
I loaded the image WinCe6 on a VF61.
I inserted this board VF61 on the toradex developer mainboard and I set the SODIMM 137 to high using
the Vybrid GPIO, and after about 4 hours the window doesn’t work.
I want to understand if I need to set some GPIOs or Register
when SODIMM 137 to high in order to the window runs correctly.
