I want to flash wince in colibri VF50.
And then i want to create devlopmemt environment on wince for visual studio and remote debugging.
I hope you can understand my concern.
Please respond to me as soon as possible.
I am waiting for your reply.
Hi @Nasir,
If you have a new Colibri VF50 then you can simply go to the update tool (Start->Programs->ColirbiTools->UpdateTool->Update) and give the path of the image that you want to update to.
The path of your WinCE image can be your SD card/Pd drive
Debug messages by default come on UART_A, see the datasheet of the viola board, and navigate to the extension connector, look for UART_A. The Rx and Tx are of TTL level and you need TTL to USB converter.
The terminal application for PC, there are many applications available. I use TeraTerm
How to connect my pc(Win10) with Viola board please explain step by step?
Which application we need to use open terminal in Win10 pc?
Note : I have fresh Colibri VF50 card.
Hello @sahil.tx sir
I want to create devlopmemt environment on apalis imx6 now.
I have ixora board and apalis imx6 card.
So please help me.
How to install WinCe 2013?
How to debug and deploy code on module via visual studio?
Thanks you.
