The length of the RTS signal is shorter than the length of the transmitted byte or vice versa is much longer than the transmitted byte.
Tested on VF50-128MB-v1.2 and VF61-256MB-IT-V1.1B, Vybrid WINCE6 image 1.3beta1. COM1 and COM2 exhibit the same mistake.
Colibri modules VF50 and VF61 are not designed for professional work.
I installed the new version 1.3 Beta 2. In this version has some RS485 works.
But work stopped NTP service. In the previous version worked.
Not working time synchronization with NTP server.
Time can not be set manually. After setting new values, the time will return to its previous value.
Hi, please do not comment on closed questions. This fix was included in our image you can download from a developers website. https://developer.toradex.com/
This fix was included in WinCE image. If you have a question related to Linux please open new question and tag it properly.
