Verdin iMX95 Hexa 8GB WB IT
I just started working with Verdin Carrier v1.1F and verdin iMX95 Hexa. Unboxed for the first time. I powered ON the board first time and I see the menu for “Toradex installer 7.8.0” on HDMI monitor. I choose to install “Torizon OS Easy pairing”. After installation is complete, when I rebooted. Nothing comes up - nothing on HDMI, cannot ping, nothing on COM port. All the LEDs on the board flashes every few seconds.
How I recover.
I understand you’re experiencing a boot issue with your Verdin iMX95 after installing Torizon OS Easy Pairing. Let me guide you through the recovery process.
Recovery Steps
To recover your Verdin iMX95, you’ll need to reload Toradex Easy Installer and reinstall the operating system. Here’s how:
1. Put Your Module in Recovery Mode
You need to enter recovery mode on your Verdin iMX95 with the Verdin Development Board. Follow the specific instructions for your hardware combination(1).
2. Download Toradex Easy Installer
Download the latest Toradex Easy Installer image for Verdin iMX95 from the Toradex download page(1).
3. Load TEZI via USB OTG
After entering recovery mode, load Toradex Easy Installer through the USB OTG interface:
  • Unzip the downloaded Toradex Easy Installer package
  • Change to the unzipped directory
  • Run the recovery script from your host machine(1):
On Linux:
$ cd <unzipped directory>
$ ./recovery-linux.sh
On Windows:
$ recovery-windows.bat
4. Reinstall the Operating System
Once Toradex Easy Installer loads and displays on your HDMI monitor, select and install your desired Torizon OS image again(1).
Important Notes
  • Ensure your HDMI display/monitor is connected to the carrier board before powering on, as HDMI hotplug is not supported(1)
  • Avoid using a USB Hub between your PC and the USB OTG port(1)
  • Avoid using Virtual Machines for the recovery process(1)
  • The recovery process loads TEZI into RAM, so you’ll need to repeat these steps if you power off before completing the OS installation(1)
Verdin iMX95 Support Status
Note that Verdin iMX95 is currently a sample product. Support for Verdin iMX95 was added starting with Torizon OS 7.4.0(2), and it’s intended for evaluation and development rather than production use at this stage(2)(3).
If you continue experiencing issues after following these recovery steps, please share any error messages you see during the recovery or installation process.
Malati,
To recover your module please follow Toradex AI instruction.
Alexander Samutin
Toradex
Senior Field Application Engineer
