Hi everyone,
I am using a custom carrier board with a Verdin iMX8MP running Torizon OS.
I am trying to use SPI2 (ECSPI2) through spidev, but although Linux seems to configure everything correctly, I do not see any physical activity on the SPI pins with the osciloscope.
Environment
Module: Verdin iMX8MP
OS: Torizon OS 7.6.1
Custom carrier board
Built using TorizonCore Builder / OSTree
Loaded overlays
Current overlays loaded:
ls /proc/device-tree/chosen/overlays
Output:
ATE_Controller_Board_i2c5_overlay.dtbo ATE_Controller_Board_spi2_overlay.dtbo verdin-imx8mp_hdmi_overlay.dtbo
ATE_Controller_Board_i2c6_overlay.dtbo name verdin-imx8mp_spidev_overlay.dtbo
SPI devices
ls -l /sys/bus/spi/devices/
Output:
total 0
lrwxrwxrwx 1 root root 0 May 21 16:01 spi1.0 -> ../../../devices/platform/soc@0/30800000.bus/30800000.spba-bus/30820000.spi/spi_master/spi1/spi1.0
lrwxrwxrwx 1 root root 0 May 21 16:01 spi2.0 -> ../../../devices/platform/soc@0/30800000.bus/30800000.spba-bus/30830000.spi/spi_master/spi2/spi2.0
I am specifically trying to use:
/dev/spidev2.0 -> 30830000.spi -> ECSPI2
SPI2 pinmux status
sudo cat /sys/kernel/debug/pinctrl/30330000.pinctrl/pinmux-pins | grep -i ecspi2
Output:
pin 124 (MX8MP_IOMUXC_ECSPI2_SCLK): 30830000.spi (GPIO UNCLAIMED) function pinctrl group ecspi2customgrp
pin 125 (MX8MP_IOMUXC_ECSPI2_MOSI): 30830000.spi (GPIO UNCLAIMED) function pinctrl group ecspi2customgrp
pin 126 (MX8MP_IOMUXC_ECSPI2_MISO): 30830000.spi (GPIO UNCLAIMED) function pinctrl group ecspi2customgrp
pin 127 (MX8MP_IOMUXC_ECSPI2_SS0): 30830000.spi 30240000.gpio:141 function pinctrl group ecspi2customgrp
So Linux seems to properly mux ECSPI2 to the SPI controller.
Pins used on my custom carrier
I am using the standard Verdin SPI2 pins:
X1 pin 95 -> ECSPI2_SCLK
X1 pin 93 -> ECSPI2_MOSI
X1 pin 14 -> ECSPI2_MISO
X1 pin 12 -> ECSPI2_SS0
These are routed directly on my custom board.
Overlay used for SPI2
/dts-v1/;
/plugin/;
#include "imx8mp-pinfunc.h"
compatible = "toradex,verdin-imx8mp";
&uart4 {
status = "disabled";
&ecspi2 {
#address-cells = <1>;
#size-cells = <0>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_ecspi2_custom>;
cs-gpios = <&gpio5 13 GPIO_ACTIVE_LOW>
spidev@0 {
compatible = "rohm,dh2228fv";
reg = <0>;
spi-max-frequency = <1000000>;
&iomuxc {
pinctrl_ecspi2_custom: ecspi2customgrp {
fsl,pins = <
MX8MP_IOMUXC_ECSPI2_SCLK__ECSPI2_SCLK 0x140
MX8MP_IOMUXC_ECSPI2_MOSI__ECSPI2_MOSI 0x140
MX8MP_IOMUXC_ECSPI2_MISO__ECSPI2_MISO 0x140
MX8MP_IOMUXC_ECSPI2_SS0__GPIO5_IO13 0x140
SPI test application
Python spidev test:
import spidev
import time
spi = spidev.SpiDev()
spi.open_path("/dev/spidev2.0")
spi.mode = 0
spi.bits_per_word = 8
spi.max_speed_hz = 1000
while True:
spi.xfer2([0xAA])
print("transfer")
time.sleep(0.1)
The transfers execute correctly and always return 0xFF without errors. But i can´t see anything on the SPI lines with an oscillosope.
Has anyone seen a similar issue or can confirm whether any additional configuration is required for ECSPI2 on Verdin iMX8MP?
Thanks!
