Hello Richard,
Thank you for reaching out with your question. You’re correct that the Verdin iMX8MM module uses AHAB (Advanced High Assurance Boot) rather than HABv4. The error you’re encountering suggests that the build process is mistakenly looking for a certificate file associated with HABv4, which is not applicable for AHAB.
To address this issue, please consider the following steps:
Verify CST Tool Configuration: Ensure that your Code Signing Tool (CST) is set up specifically for AHAB. It should not generate or expect HABv4-related files like
CSF1_1_sha256_2048_65537_v3_usr_crt.pem. Double-check the version and configuration of your CST to confirm it aligns with AHAB requirements. -
Check Certificate Files: Make sure the certificates and keys you generated are intended for AHAB. The AHAB process involves different certificate handling compared to HABv4. Verify that the paths and filenames in your build configuration match those of the AHAB-specific certificates.
Review Yocto Configuration: In your
local.conf, ensure that the secure boot settings are correctly specified for AHAB. This includes any references to certificate files and paths. If your configuration mistakenly includes HABv4 settings, adjust them to reflect AHAB requirements. -
Consult NXP Documentation: Reviewing the NXP documentation for AHAB on the i.MX 8M Mini can provide additional insights into the correct setup and any nuances that might affect your build process.
Rebuild with Correct Settings: After verifying and correcting your setup, attempt to rebuild the image. Ensure that all paths and configurations are updated to reflect the AHAB process.
By ensuring that your build environment and configurations are tailored for AHAB, you should be able to resolve the missing certificate file error and successfully create a secure boot image for your Verdin iMX8MM module.
I hope this helps! If you have any further questions, feel free to ask.
Toradex AI Assistant
