Hi all!
Thanks for clarifying about the patch and testing it!
I will bring it up internally.
Hi all!
Hi all!
Coming back here to give feedback related to the patch shared by @dobrev.
Since this patch is already available in u-boot upstream, it will not be backported to Toradex’s BSP since upcoming versions of our BSP will get this patch “for free”.
Anyways, thanks to @dobrev and @JSR for bringing this up ![]()
Have a nice day!
I’m thinking about production fusing. Of course it should be done from Tezi. Old Tezi 1.8 supports named fuse words like
/sys/fsl_otp/HW_OCOTP_SRK0
, which are quite straight forward to construct wrapup.sh.
Newer Tezi’s have single file /sys/bus/nvmem/devices/imx-ocotp0/nvmem, which is easy to make unbootable with wrong "dd skip= " in script.
The best would be if wrapup.sh was compatible with old and new Tezi. That’s a piece of work to debug…
Hi @Edward !
Sorry, but I didn’t understand… how is your message related to this thread?
It is better to create a new thread to start a new discussion.
That security recipe and the “HAB” in subject is about HAB. What security recipe makes at the end at least HAB authenticated u-boot and instructions in txt file how to fuse end engage security from u-boot console. Letting production staff using not only Tezi, but as well booting into u-boot (ehh, what about u-boot hardening with cli disabled???) and copy pasting u-boot fuse command instructions from txt. This is at least error prone. Am I really off topic?
Hi @Edward !
Indeed your considerations are related to the top-level subject here (HAB, secure boot, …).
But it is better to create a new ticket when the specific topic is not the same. Not to mention that this topic is already marked as solved.
Could you please create a new topic so we can discuss your (IMO very reasonable) considerations? If you want, you can refer to this topic in your new topic.
Thank you for the comprehension ![]()
