Verdin IMX8M Plus change serial debug console
I am using Verdin IMX8M Plus module. I want to change the Default Console connection to UART2 instead of UART3. How can I do it?
Hi @eepvs ,
When do you want to start having access to the console: From the bootloader, from the kernel?
The way to change the console output depends on your specific use-case.
Can you detail why you would want to change the default console?
Lucas Akira
