I see I can buy a Verdin heatsink from Toradex, which is compatible with the Verdin iMX8M Plus and the Verdin iMX8M Mini SoMs.
But I see tha SoM with WiFi have the receptacles for antennas.
How can the heatsink suit in this case?
Should I design/produce my own heatsink in this case?
Or buy the standard one and modify it cutting away some materials corresponding to the position of receptacles?
Hello @vix ,
The heatsink does not actually touch the WiFi module, and does not interfere with the antennas.
You simply attach the antennas first and then you install the heatsink.
Here is a closeup with the antenna cables.
Josep
Hello @josep.tx
from your picture I understand that I must use an antenna cable with a 90° connector, so that it doesn’t touch the heatsink vertically
