Thank you, Daniel! Thank you for your kindness and attention to help me! Have a great afternoon!
Daniel, I made the connection of the encoder with the pullup resistors, I used a multimeter to validate the operation. It’s all OK. Thank you very much.
My qt code understands the encoder step as keyboard commands, decrement is key_left and increment is key_right. How to do this implementation? Do I have to add some other driver? Or make any changes to the module?
Hi @allanbic ,
About the qt integration, please check the information provided on this article from Qt Company.
Daniel Morais
Daniel, good afternoon! How are you?
I had already checked this file at another time. I made the settings, because without success! The problem I’m having is the following: my application understands the encoder as if it were a keyboard signal, check the following snippet:
void FControl::onKeyPress(int Key)
qDebug() << "received";
qDebug() << Page;
int press;
switch(key)
case Qt::Key_Enter:
case Qt::Key_Return:
press=0;
break;
case Qt::Key_Left:
press= -120;
break;
case Qt::Key_Right:
press= +120;
break;
How do I make the system understand that the encoder increment is Key_Left and Key_Right decrement?
I believe I should have to direct this in a module, correct? If yes, how to do it? Thanks for listening!
