We have been working on the imx8 mini using a Verdin development board…
As we are in the process of designing our PCB, I was wondering if VCC_BACKUP is necessary since I found that it is only necessary for RTC. Otherwise, if we have to use it for other purposes, I would like to know why. Thanks for taking your time and support.
The 5V from the USB is directly connected to the VCC input voltage of the module. No further buck regulator is needed. The module starts automatically when the VCC is applied. The VCC_BACKUP is not required for running the module. However, without a coin cell battery on VCC_BACKUP, the real-time clock is only running if the VCC rail is available.
Therefore, you wouldn’t need the VCC_BACKUP to run the module but it’s highly desirable to have it if you want to use the RTC functionalities all the time.
