Hi all
I’m currently trying to use the meta buildtool Yocto Cooker (GitHub - cpb-/yocto-cooker: Meta buildtool for Yocto Project based Linux embedded systems) to create Images for a iMX6 board.
After starting the tool (menu file), it throws a few erros: full log
ERROR: base-files-3.0.14-r89 do_fetch: Fetcher failure: Unable to find file
ERROR: linux-toradex-5.4.77+gitAUTOINC+a2f08dfd79-r0 do_fetch: Fetcher failure: Unable to find file
When I use bitbake in the oe-core folder with the local.conf, it works.
Yocto Cooker uses the . poky/oe-init-build-env script, maybe I have to change something there but at the moment, I have no idea what the problem could be …
Thanks a lot for your help
Chris
