Using terminal with USB Host
How can i connect to colibri’s terminal with USB Host(x11 port of Iris Carrier Board)?
Hi @ogusis01 !
What do you mean by “terminal”? Would it be the serial console where we can see the messages printed during the boot process of the module?
If yes, please follow the getting started guide: Quickstart Guide | Toradex Developer Center
Actually, you can’t access the serial console from USB interface in Iris. You will need a RS-232 - USB adapter connected to the X13 header.
