I am trying to display and record at the same time after capturing a video from usb camera. I have trouble in displaying video on screen when I use splitmuxsink. When I use multifilesink instead of splitmuxsink, I can get video on screen. As you see the below, when I use splitmuxsink, I don’t see “v4l2sink need allocate 3 buffers.”.
Am I using splitmuxsink wrong?
Please refer to the below.
Thank you
root@apalis-imx6:~# uname -a
Linux apalis-imx6 4.1.44-2.7.4+gb1555bf #1 SMP Wed Oct 4 22:39:51 UTC 2017 armv7l GNU/Linux
root@apalis-imx6:~# gst-launch-1.0 imxv4l2src device=/dev/video1 ! capsfilter caps="video/x-raw,width=1920, height=1080, framerate=30/1" ! tee name=t ! queue ! imxv4l2sink sync=false t. ! queue ! vpuenc_h264 ! multifilesink location=/media/sda1/%d.264 next-file=5 max-file-duration=60000000000 sync=false
[ 23.745257] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 24.392659] ov5640_set_virtual_channel: virtual channel=1
[ 24.937070] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
====== IMXV4L2SRC: 4.1.4 build on Oct 4 2017 23:03:28. ======
====== IMXV4L2SINK: 4.1.4 build on Oct 4 2017 23:03:28. ======
Setting pipeline to PAUSED ...
display(/dev/fb0) resolution is (640x480).
[INFO] Product Info: i.MX6Q/D/S
====== VPUENC: 4.1.4 build on Oct 4 2017 23:03:36. ======
wrapper: 1.0.68 (VPUWRAPPER_ARM_LINUX Build on Oct 4 2017 22:43:46)
vpulib: 5.4.35
firmware: 3.1.1.46072
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
[ 25.285041] ov5640_set_virtual_channel: virtual channel=1
[INFO] ringBufferEnable 0, chromaInterleave 0, mapType 0, linear2TiledEnable 0
root@apalis-imx6:~# gst-launch-1.0 imxv4l2src device=/dev/video1 ! capsfilter caps="video/x-raw,width=1920, height=1080, framerate=30/1" ! tee name=t ! queue ! imxv4l2sink sync=false t. ! queue ! vpuenc_h264 ! splitmuxsink location=/media/sda1/%d.264 max-size-time=60000000000 sync=false
[ 95.743239] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 96.385911] ov5640_set_virtual_channel: virtual channel=1
[ 96.909589] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
vpulib: 5.4.35
[ 97.297284] ov5640_set_virtual_channel: virtual channel=1
