I’m using Colibri iMX8QPX on Iris carrier board with DSI to HDMI Adapter.
This works correctly with previous version using meta-fsl-bsl-release/toradex-sumo-4.14.78-1.0.0_ga-bringup, but no longer with the latest meta-toradex* BSP release 3.0b2.
Changing to fsl-imx8qxp-colibri-dsihdmi-eval-v3.dtb causes lots of kernel stack traces during boot:
[ 2.116665] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 2.125115] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 2.132659] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 2.140153] ------------[ cut here ]------------
[ 2.144792] WARNING: CPU: 2 PID: 1 at /work/build/build/tmp/work-shared/colibri-imx8x/kernel-source/drivers/gpu/drm/drm_bridge.c:155 drm_bridge_detach+0x44/0x50
[ 2.159155] Modules linked in:
[ 2.162222] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.14.117-0+ge43e3a26e1b7 #1
[ 2.169720] Hardware name: Toradex Colibri iMX8QXP/DX with LT8912 MIPI-DSI 2 HDMI bridge (DT)
[ 2.178260] task: ffff80007a3b8000 task.stack: ffff000008048000
[ 2.184191] PC is at drm_bridge_detach+0x44/0x50
[ 2.188814] LR is at drm_encoder_cleanup+0x28/0xa0
[ 2.193616] pc : [<ffff0000086e5be4>] lr : [<ffff0000086e9218>] pstate: 60000045
[ 2.201019] sp : ffff00000804ba90
[ 2.204341] x29: ffff00000804ba90 x28: 0000000000000000
[ 2.209659] x27: 0000000000000000 x26: 0000000000000001
[ 2.214985] x25: ffff0000093ab960 x24: ffff000008fcc598
[ 2.220310] x23: ffff80007aa7c800 x22: ffff000008fcc1e0
[ 2.225636] x21: ffff80007aa7c800 x20: 0000000000000000
[ 2.230961] x19: ffff80007aa7c030 x18: 00000000fffffffd
[ 2.236286] x17: 0000000000000000 x16: 0000000000000000
[ 2.241612] x15: 0000000000000001 x14: ffffffffffffffff
[ 2.246938] x13: ffff80007afd1d07 x12: ffff80007afd1d04
[ 2.252263] x11: 0000000000000038 x10: 0101010101010101
[ 2.257588] x9 : 0000000000000002 x8 : 0000000000000002
[ 2.262914] x7 : ffff0000090c0d70 x6 : 000000000000008c
[ 2.268239] x5 : 0000000000000090 x4 : 0000000000000000
[ 2.273564] x3 : 0000000000000040 x2 : 0000000000000000
[ 2.278890] x1 : 0000000000000000 x0 : ffff80007aa7c030
[ 2.284217] Call trace:
[ 2.286667] Exception stack(0xffff00000804b950 to 0xffff00000804ba90)
[ 2.293115] b940: ffff80007aa7c030 0000000000000000
[ 2.300965] b960: 0000000000000000 0000000000000040 0000000000000000 0000000000000090
[ 2.308808] b980: 000000000000008c ffff0000090c0d70 0000000000000002 0000000000000002
[ 2.316655] b9a0: 0101010101010101 0000000000000038 ffff80007afd1d04 ffff80007afd1d07
[ 2.324498] b9c0: ffffffffffffffff 0000000000000001 0000000000000000 0000000000000000
[ 2.332343] b9e0: 00000000fffffffd ffff80007aa7c030 0000000000000000 ffff80007aa7c800
[ 2.340188] ba00: ffff000008fcc1e0 ffff80007aa7c800 ffff000008fcc598 ffff0000093ab960
[ 2.348032] ba20: 0000000000000001 0000000000000000 0000000000000000 ffff00000804ba90
[ 2.355878] ba40: ffff0000086e9218 ffff00000804ba90 ffff0000086e5be4 0000000060000045
[ 2.363722] ba60: ffff80007aa7c030 ffff80007afb2e18 ffffffffffffffff ffff000008fcc1e0
[ 2.371567] ba80: ffff00000804ba90 ffff0000086e5be4
[ 2.376455] [<ffff0000086e5be4>] drm_bridge_detach+0x44/0x50
[ 2.382128] [<ffff0000086e9218>] drm_encoder_cleanup+0x28/0xa0
[ 2.387979] [<ffff00000870a8f4>] imx_nwl_dsi_bind+0x104/0x178
[ 2.393737] [<ffff000008720bb8>] component_bind_all+0xf8/0x260
[ 2.399583] [<ffff000008705fb8>] imx_drm_bind+0x1e0/0x2f8
[ 2.404994] [<ffff000008720824>] try_to_bring_up_master+0x14c/0x1a8
[ 2.411275] [<ffff000008720918>] component_add+0x98/0x160
[ 2.416687] [<ffff0000087110b0>] dpu_bliteng_probe+0x20/0x30
[ 2.422362] [<ffff000008728758>] platform_drv_probe+0x58/0xb8
[ 2.428120] [<ffff0000087268d4>] driver_probe_device+0x204/0x2c0
[ 2.434140] [<ffff000008726a48>] __driver_attach+0xb8/0xc0
[ 2.439640] [<ffff000008724b1c>] bus_for_each_dev+0x6c/0xa8
[ 2.445224] [<ffff0000087260c8>] driver_attach+0x20/0x28
[ 2.450550] [<ffff000008725dcc>] bus_add_driver+0x1dc/0x208
[ 2.456138] [<ffff000008727688>] driver_register+0x60/0xf8
[ 2.461636] [<ffff0000087286ac>] __platform_driver_register+0x44/0x50
[ 2.468095] [<ffff000009561a58>] dpu_bliteng_driver_init+0x1c/0x24
[ 2.474287] [<ffff000008083c08>] do_one_initcall+0x38/0x11c
[ 2.479873] [<ffff000009500cd4>] kernel_init_freeable+0x17c/0x210
[ 2.485982] [<ffff000008e4727c>] kernel_init+0x10/0xfc
[ 2.491129] [<ffff000008084e90>] ret_from_fork+0x10/0x18
[ 2.496459] ---[ end trace a28a4ec5ff94382e ]---
[ 2.501126] imx-drm display-subsystem: failed to bind mipi_dsi@56228000 (ops imx_nwl_dsi_component_ops): -517
[ 2.511280] imx-drm display-subsystem: master bind failed: -517
