Use a credential helper to handle docker authentication on Torizon OS
Based on the context provided, there is no specific information about setting up a credential helper for Docker authentication on Torizon OS. The context discusses using the TorizonCore Builder Tool and Torizon Remote Updates to manage Docker credentials, but it does not mention configuring a credential helper to store credentials securely.
To address the warning about storing passwords unencrypted, you would typically configure a credential helper as suggested in the Docker documentation. However, without specific instructions or documentation from Toradex on setting this up in Torizon OS, I cannot provide a detailed solution.
I recommend checking the official Docker documentation for setting up a credential helper and seeing if it can be adapted for use on Torizon OS. Additionally, reaching out to Toradex support or community forums might provide more specific guidance or updates on this topic.
Imx8x Torizon 5.7.2 to 6.3 Upgrade Journey - permissions on /etc/docker wrong on update.
