I´m trying to get a usb camera with proprietary drivers working on iMX7D. On a Raspberry Pi it is working with the same procedure but on the iMX7 not. I´m using an Angstrom Linux version 4.9.220-2.8.7+g5722926 built from the yocto demo image (I also tried with and without LXDE desktop, but same behaviour)
After installing the drivers without any error messages and connecting the device it is recognised by the system, as this line appears on iMX7:
[ 11.284091] usb 1-1: new high-speed USB device number 3 using ci_hdrc
On Raspberry Pi there are more lines after plugging in the device:
[25083.837244] usb 1-1.3: new high-speed USB device number 12 using xhci_hcd
[25083.967677] usb 1-1.3: New USB device found, idVendor=1409, idProduct=1645, bcdDevice= 0.00
[25083.967693] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
On the iMX7 the camera cannot be used and is not recognised by the software.One difference that I found is that on the Pi there is automatically usbfs loaded as a driver, here is the lsusb -t output:
|__ Port 3: Dev 9, If 0, Class=Vendor Specific Class, Driver=usbfs, 480M
But on iMX7 the driver field stays empty:
|__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=, 480M
So to fix this I tried to load the driver manually by writing 1-1:1.0 into /sys/bus/usb/drivers/usbfs/bind, but it says that the device cannot be found. But this seems to be expected behaviour as explained in this thread:
And indeed on the Pi after unbinding the driver usbfs and trying to bind it again there is the same error message and the driver cannot be loaded manually … The driver can be loaded again after unplugging the device
As further information here is the output of ls -l /sys/bus/usb/devices/1-1.3:1.0/ on the Pi:
insgesamt 0
-rw-r--r-- 1 root root 4096 Dez 30 14:10 authorized
-r--r--r-- 1 root root 4096 Dez 30 14:09 bAlternateSetting
-r--r--r-- 1 root root 4096 Dez 30 14:08 bInterfaceClass
-r--r--r-- 1 root root 4096 Dez 30 14:08 bInterfaceNumber
-r--r--r-- 1 root root 4096 Dez 30 14:09 bInterfaceProtocol
-r--r--r-- 1 root root 4096 Dez 30 14:09 bInterfaceSubClass
-r--r--r-- 1 root root 4096 Dez 30 14:08 bNumEndpoints
lrwxrwxrwx 1 root root 0 Dez 30 14:08 driver -> ../../../../../../../../../../../bus/usb/drivers/usbfs
drwxr-xr-x 3 root root 0 Dez 30 14:10 ep_06
drwxr-xr-x 3 root root 0 Dez 30 14:10 ep_82
-r--r--r-- 1 root root 4096 Dez 30 14:10 modalias
drwxr-xr-x 2 root root 0 Dez 30 14:10 power
lrwxrwxrwx 1 root root 0 Dez 30 14:10 subsystem -> ../../../../../../../../../../../bus/usb
-r--r--r-- 1 root root 4096 Dez 30 14:10 supports_autosuspend
-rw-r--r-- 1 root root 4096 Dez 30 14:08 uevent
And here as a comparison the output of ls -l /sys/bus/usb/devices/1-1:1.0/ on the iMX7:
-rw-r--r-- 1 root root 4096 Oct 20 14:15 authorized
-r--r--r-- 1 root root 4096 Oct 20 14:01 bAlternateSetting
-r--r--r-- 1 root root 4096 Oct 20 13:54 bInterfaceClass
-r--r--r-- 1 root root 4096 Oct 20 14:01 bInterfaceNumber
-r--r--r-- 1 root root 4096 Oct 20 13:54 bInterfaceProtocol
-r--r--r-- 1 root root 4096 Oct 20 13:54 bInterfaceSubClass
-r--r--r-- 1 root root 4096 Oct 20 14:01 bNumEndpoints
-r--r--r-- 1 root root 4096 Oct 20 14:15 modalias
drwxr-xr-x 2 root root 0 Oct 20 14:15 power
lrwxrwxrwx 1 root root 0 Oct 20 14:15 subsystem -> ../../../../../../../../../bus/usb
-r--r--r-- 1 root root 4096 Oct 20 14:15 supports_autosuspend
-rw-r--r-- 1 root root 4096 Oct 20 13:54 uevent
This also shows that no driver is loaded automatically…
So my question is:
- Why is usbfs not loaded automatically? If I understand it correctly it should load automatically…
- And is there a possibility to solve this? Either load it manually or change something in the yocto build?
- Or might there be another problem that I´m not aware of?
