Hope you are well. I’m trying incorporate a USB hub controller like the one used in your development board.
The Datasheet for the Development Board specifies using a USB5744T-I/2G USB hub controller, however this part is sold out anywhere.
Please advise, what is a pin compatible alternate USB hub controller to the USB5744T-I/2G that we can use in our designs?
Sorry, we have no such information. I’d address this question to MIcrochip. But apart from pin compatibility you can use pretty much any USB3 hub IC. Or even USB2 if you don’t need USB3 for your device
