Dear guys,
I have a problem with toradex USB adapter on IMX6ULL image.
I inserted the USB wifi adapter but when I don’t find the Wifi port when
I do connmann-properties.
I tried to do the command lsusb and the USB wifi adapter exists on the device lists:
Bus 001 Device 003: ID 1c4f:0034 SiGma Micro
Bus 001 Device 005: ID 04d9:a088 Holtek Semiconductor, Inc.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Bus 001 Device 002: ID 058f:6254 Alcor Micro Corp. USB Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
A while ago we’ve tested a SparkLAN WUBR-508N 802.11abgn USB Adaptor with 2.8BSP. We have not tested it with BSP V3 and beyond, so we cannot guarantee that it will work out of the box.
We have a Colibri iMX6Ull module with WiFI/BT module onboard.
Dear @alex.tx,
Yes, my wifi adapter is that.
Is It possibile to use on imx6ull Linux.
is there any wifi adapter compatible with imx6ull?
Thank you
Best regards
Matteo
Dear alex, i have same issue, i need to use an USB WiFi dongle with IMX6ULL.
Unfortunately i cannot use MX6Ull module with WiFI/BT module onboard because WiFi is an option.
Please can you suggest me some USB dongle that can work with linux?
If not, at least a chipset that should work.
Is the Realtek RTL8188CUS/RTL8188EUS chipset supported into IMX6ULL linux image?
Tks
Roberto
