dmesg gives the following:
dmesg
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.14.52-v2.6b2+g9ace52b (greg@Embedded-Builder) (g6
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie
[ 0.000000] Machine model: Toradex Colibri iMX7S on Colibri Evaluation Board3
[ 0.000000] cma: CMA: reserved 128 MiB at 88000000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 65536
[ 0.000000] free_area_init_node: node 0, pgdat 8093e1c0, node_mem_map 87dba00
[ 0.000000] Normal zone: 512 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 65536 pages, LIFO batch:15
[ 0.000000] PERCPU: Embedded 7 pages/cpu @87d8d000 s7936 r8192 d12544 u32768
[ 0.000000] pcpu-alloc: s7936 r8192 d12544 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa4
[ 0.000000] Kernel command line: ubi.mtd=ubi root=ubi0:rootfs rootfstype=ubi)
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 118484K/262144K available (6659K kernel code, 308K rwdat)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0x90800000 - 0xff000000 (1768 MB)
[ 0.000000] lowmem : 0x80000000 - 0x90000000 ( 256 MB)
[ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
[ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
[ 0.000000] .text : 0x80008000 - 0x808a914c (8837 kB)
[ 0.000000] .init : 0x808aa000 - 0x808f1f00 ( 288 kB)
[ 0.000000] .data : 0x808f2000 - 0x8093f240 ( 309 kB)
[ 0.000000] .bss : 0x8093f248 - 0x809a3e98 ( 404 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] i.MX timer: unable to get clk
[ 0.000000] Architected cp15 timer(s) running at 8.00MHz (phys).
[ 0.000008] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2147s
[ 0.000016] Switching to timer-based delay loop
[ 0.000622] Console: colour dummy device 80x30
[ 0.001032] console [tty1] enabled
[ 0.001056] Calibrating delay loop (skipped), value calculated using timer f)
[ 0.001085] pid_max: default: 32768 minimum: 301
[ 0.001248] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001270] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.005829] device-tree: Duplicate name in /soc/aips-bus@30400000/lcdif@3073"
[ 0.009140] Initializing cgroup subsys debug
[ 0.009168] Initializing cgroup subsys freezer
[ 0.009216] CPU: Testing write buffer coherency: ok
[ 0.009496] /cpus/cpu@0 missing clock-frequency property
[ 0.009522] /cpus/cpu@1 missing clock-frequency property
[ 0.009543] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.009582] Setting up static identity map for 0x8065b3d8 - 0x8065b430
[ 0.010670] CPU1: failed to boot: -38
[ 0.010714] Brought up 1 CPUs
[ 0.010731] SMP: Total of 1 processors activated (16.00 BogoMIPS).
[ 0.010746] CPU: All CPU(s) started in SVC mode.
[ 0.011323] devtmpfs: initialized
[ 0.015547] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5
[ 0.015900] pinctrl core: initialized pinctrl subsystem
[ 0.016281] regulator-dummy: no parameters
[ 0.025593] device-tree: Duplicate name in lcdif@30730000, renamed to "displ"
[ 0.030136] NET: Registered protocol family 16
[ 0.036833] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.037617] cpuidle: using governor ladder
[ 0.037639] cpuidle: using governor menu
[ 0.046464] syscon 30340000.iomuxc-gpr: regmap [mem 0x30340000-0x3034ffff] rd
[ 0.046742] syscon 30350000.ocotp-ctrl: regmap [mem 0x30350000-0x3035ffff] rd
[ 0.047155] syscon 30360000.anatop: regmap [mem 0x30360000-0x3036ffff] regisd
[ 0.048335] syscon 30390000.src: regmap [mem 0x30390000-0x3039ffff] registerd
[ 0.050123] DDR type is DDR3!
[ 0.054558] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint.
[ 0.054587] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.054897] imx7d-pinctrl 302c0000.iomuxc-lpsr: initialized IMX pinctrl drivr
[ 0.056190] imx7d-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.057526] MU is ready for cross core communication!
[ 0.065198] bio: create slab <bio-0> at 0
[ 0.067678] mxs-dma 33000000.dma-apbh: initialized
[ 0.068315] 3P3V: 3300 mV
[ 0.068391] reg-fixed-voltage 3p3v.17: 3P3V supplying 3300000uV
[ 0.068593] usb_otg2_vbus: 5000 mV
[ 0.068664] reg-fixed-voltage 1.regulator: usb_otg2_vbus supplying 5000000uV
[ 0.068840] vref-1v8: 1800 mV
[ 0.068903] reg-fixed-voltage regulator.18: vref-1v8 supplying 1800000uV
[ 0.069508] SCSI subsystem initialized
[ 0.069835] usbcore: registered new interface driver usbfs
[ 0.069922] usbcore: registered new interface driver hub
[ 0.070121] usbcore: registered new device driver usb
[ 0.070314] usb_phy_gen_xceiv usbphy_nop1.12: Looking up vcc-supply from deve
[ 0.070329] usb_phy_gen_xceiv usbphy_nop1.12: Looking up vcc-supply propertyd
[ 0.070340] usbphy_nop1.12 supply vcc not found, using dummy regulator
[ 0.070451] usb_phy_gen_xceiv usbphy_nop3.13: Looking up vcc-supply from deve
[ 0.070481] platform usbphy_nop3.13: Driver usb_phy_gen_xceiv requests probel
[ 0.072191] i2c i2c-0: IMX I2C adapter registered
[ 0.072868] i2c i2c-3: IMX I2C adapter registered
[ 0.072986] Linux video capture interface: v2.00
[ 0.073047] pps_core: LinuxPPS API ver. 1 registered
[ 0.073063] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[ 0.073104] PTP clock support registered
[ 0.073501] Advanced Linux Sound Architecture Driver Initialized.
[ 0.074379] Bluetooth: Core ver 2.18
[ 0.074433] NET: Registered protocol family 31
[ 0.074451] Bluetooth: HCI device and connection manager initialized
[ 0.074477] Bluetooth: HCI socket layer initialized
[ 0.074498] Bluetooth: L2CAP socket layer initialized
[ 0.074543] Bluetooth: SCO socket layer initialized
[ 0.075164] Switched to clocksource arch_sys_counter
[ 0.078543] cfg80211: Calling CRDA to update world regulatory domain
[ 0.085346] NET: Registered protocol family 2
[ 0.086220] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.086271] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.086324] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.086382] TCP: reno registered
[ 0.086403] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.086445] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.086688] NET: Registered protocol family 1
[ 0.086977] RPC: Registered named UNIX socket transport module.
[ 0.087000] RPC: Registered udp transport module.
[ 0.087014] RPC: Registered tcp transport module.
[ 0.087029] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.088802] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.088909] imx rpmsg driver is registered.
[ 0.088994] imx_busfreq: probe of busfreq.3 failed with error 12
[ 0.089152] Bus freq driver module loaded
[ 0.089958] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.097865] VFS: Disk quotas dquot_6.5.2
[ 0.098163] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.100547] NFS: Registering the id_resolver key type
[ 0.100621] Key type id_resolver registered
[ 0.100638] Key type id_legacy registered
[ 0.100682] jffs2: version 2.2. (NAND) ?© 2001-2006 Red Hat, Inc.
[ 0.101433] fuse init (API version 7.22)
[ 0.101955] msgmni has been set to 487
[ 0.105118] io scheduler noop registered
[ 0.105142] io scheduler deadline registered
[ 0.105455] io scheduler cfq registered (default)
[ 0.107420] pwm-backlight backlight.14: Looking up power-supply from device e
[ 0.107437] pwm-backlight backlight.14: Looking up power-supply property in d
[ 0.107450] backlight.14 supply power not found, using dummy regulator
[ 0.115849] mxsfb 30730000.lcdif: Looking up lcd-supply from device tree
[ 0.115865] mxsfb 30730000.lcdif: Looking up lcd-supply property in node /sod
[ 0.115875] 30730000.lcdif supply lcd not found, using dummy regulator
[ 0.183051] mxsfb 30730000.lcdif: failed to find mxc display driver
[ 0.191819] Console: switching to colour frame buffer device 100x30
[ 0.211073] mxsfb 30730000.lcdif: initialized
[ 0.213724] imx-sdma 30bd0000.sdma: no event needs to be remapped
[ 0.215523] imx-sdma 30bd0000.sdma: loaded firmware 4.1
[ 0.220654] imx-sdma 30bd0000.sdma: initialized
[ 0.222753] Serial: IMX driver
[ 0.224919] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 58, base_baudX
[ 1.008329] console [ttymxc0] enabled
[ 1.014256] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 59, base_baudX
[ 1.025529] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 60, base_baudX
[ 1.036497] serial: Freescale lpuart driver
[ 1.043387] [drm] Initialized drm 1.1.0 20060810
[ 1.058321] brd: module loaded
[ 1.067703] loop: module loaded
[ 1.074242] DCDC1: 975 <--> 1125 mV at 1000 mV
[ 1.081735] DCDC2: 975 <--> 1125 mV at 1100 mV
[ 1.089134] DCDC3: 1775 <--> 1825 mV at 1800 mV
[ 1.096583] DCDC4: 1325 <--> 1375 mV at 1350 mV
[ 1.104004] LDO1: 1800 <--> 3300 mV at 3300 mV
[ 1.110834] LDO2: 1775 <--> 3325 mV at 3300 mV
[ 1.117677] LDO3: 3275 <--> 3325 mV at 3300 mV
[ 1.124463] LDO4: 1775 <--> 1825 mV at 1800 mV
[ 1.131216] LDO5: 1775 <--> 1825 mV at 3300 mV
[ 1.137925] LDORTC1: at 3000 mV
[ 1.143261] LDORTC2: at 900 mV
[ 1.147983] rn5t618 0-0033: probe finished ok: 0
[ 1.161226] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xdc
[ 1.169027] nand: Macronix MX30LF4G28AB
[ 1.174239] nand: 512MiB, SLC, page size: 2048, OOB size: 112
[ 1.181795] gpmi-nand 33002000.gpmi-nand: enable the asynchronous EDO mode 5
[ 1.190508] Bad block table found at page 262080, version 0x01
[ 1.197955] Bad block table found at page 262016, version 0x01
[ 1.205501] 4 cmdlinepart partitions found on MTD device gpmi-nand
[ 1.212995] Creating 4 MTD partitions on "gpmi-nand":
[ 1.219408] 0x000000000000-0x000000080000 : "mx7-bcb"
[ 1.226161] 0x000000080000-0x000000400000 : "u-boot"
[ 1.232716] 0x000000400000-0x000000480000 : "u-boot-env"
[ 1.239586] 0x000000480000-0x000020000000 : "ubi"
[ 1.246293] gpmi-nand 33002000.gpmi-nand: driver registered.
[ 1.255478] spi_imx 30840000.ecspi: probed
[ 1.261541] vcan: Virtual CAN interface driver
[ 1.267329] CAN device driver interface
[ 1.274072] fec 30be0000.ethernet: Looking up phy-supply from device tree
[ 1.274614] pps pps0: new PPS source ptp0
[ 1.282025] libphy: fec_enet_mii_bus: probed
[ 1.289114] fec 30be0000.ethernet eth0: registered PHC device 0
[ 1.296698] usbcore: registered new interface driver asix
[ 1.303635] usbcore: registered new interface driver ax88179_178a
[ 1.311298] usbcore: registered new interface driver cdc_ether
[ 1.318662] usbcore: registered new interface driver net1080
[ 1.325856] usbcore: registered new interface driver cdc_subset
[ 1.333245] usbcore: registered new interface driver zaurus
[ 1.340307] usbcore: registered new interface driver cdc_ncm
[ 1.347291] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.355164] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.361974] usbcore: registered new interface driver usb-storage
[ 1.369447] usbcore: registered new interface driver usbserial
[ 1.376651] usbcore: registered new interface driver usbserial_generic
[ 1.384488] usbserial: USB Serial support registered for generic
[ 1.391810] usbcore: registered new interface driver ftdi_sio
[ 1.398871] usbserial: USB Serial support registered for FTDI USB Serial Deve
[ 1.407614] usbcore: registered new interface driver pl2303
[ 1.414611] usbserial: USB Serial support registered for pl2303
[ 1.422925] usbmisc_imx 30b10200.usbmisc: Looking up vbus-wakeup-supply frome
[ 1.422942] usbmisc_imx 30b10200.usbmisc: Looking up vbus-wakeup-supply propd
[ 1.422960] 30b10200.usbmisc supply vbus-wakeup not found, using dummy regulr
[ 1.431977] usbmisc_imx 30b30200.usbmisc: Looking up vbus-wakeup-supply frome
[ 1.431994] usbmisc_imx 30b30200.usbmisc: Looking up vbus-wakeup-supply propd
[ 1.432004] 30b30200.usbmisc supply vbus-wakeup not found, using dummy regulr
[ 1.441534] imx_usb 30b10000.usb: Looking up vbus-supply from device tree
[ 1.441550] imx_usb 30b10000.usb: Looking up vbus-supply property in node /sd
[ 1.441562] 30b10000.usb supply vbus not found, using dummy regulator
[ 1.455206] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.461571] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.485194] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.493063] hub 1-0:1.0: USB hub found
[ 1.498373] hub 1-0:1.0: 1 port detected
[ 1.504530] mousedev: PS/2 mouse device common for all mice
[ 1.514364] input: AD7879 Touchscreen as /devices/soc.2/30800000.aips-bus/300
[ 1.530896] rtc-ds1307 3-0068: rtc core: registered m41t00 as rtc0
[ 1.539482] check_alarm_past: alarm in the past
[ 1.546029] snvs_rtc 30370034.snvs-rtc-lp: rtc core: registered 30370034.snv1
[ 1.556436] i2c /dev entries driver
[ 1.562855] imx2-wdt 30280000.wdog: IMX2+ Watchdog Timer enabled. timeout=60)
[ 1.573283] Bluetooth: HCI UART driver ver 2.2
[ 1.579697] Bluetooth: HCI H4 protocol initialized
[ 1.586474] Bluetooth: HCI BCSP protocol initialized
[ 1.593437] Bluetooth: HCIATH3K protocol initialized
[ 1.600803] usbcore: registered new interface driver bcm203x
[ 1.608549] usbcore: registered new interface driver btusb
[ 1.615930] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 1.623548] usbcore: registered new interface driver ath3k
[ 1.631023] sdhci: Secure Digital Host Controller Interface driver
[ 1.639052] sdhci: Copyright(c) Pierre Ossman
[ 1.645278] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.655401] sdhci-esdhc-imx 30b40000.usdhc: Looking up vqmmc-supply from deve
[ 1.655426] sdhci-esdhc-imx 30b40000.usdhc: Looking up vqmmc-supply propertyd
[ 1.655444] mmc0: no vqmmc regulator found
[ 1.661405] sdhci-esdhc-imx 30b40000.usdhc: Looking up vmmc-supply from devie
[ 1.661419] sdhci-esdhc-imx 30b40000.usdhc: Looking up vmmc-supply property d
[ 1.661429] mmc0: no vmmc regulator found
[ 1.715181] mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using A
[ 1.727734] caam 30900000.caam: Instantiated RNG4 SH0
[ 1.787145] caam 30900000.caam: Instantiated RNG4 SH1
[ 1.794055] caam 30900000.caam: device ID = 0x0a160300 (Era 8)
[ 1.801738] caam 30900000.caam: job rings = 3, qi = 0
[ 1.815299] caam algorithms registered in /proc/crypto
[ 1.825439] caam_jr 30901000.jr0: registering rng-caam
[ 1.833117] platform caam_sm: blkkey_ex: 8 keystore units available
[ 1.841429] platform caam_sm: 64-bit clear key:
[ 1.847596] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 1.854814] platform caam_sm: 64-bit black key:
[ 1.860842] platform caam_sm: [0000] 33 b9 60 14 dc c6 0f 16
[ 1.867957] platform caam_sm: [0008] 61 7b bc 36 32 9a 89 49
[ 1.875063] platform caam_sm: 128-bit clear key:
[ 1.881132] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 1.888285] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 1.895394] platform caam_sm: 128-bit black key:
[ 1.901471] platform caam_sm: [0000] 10 cb d4 26 90 10 a0 ba
[ 1.908602] platform caam_sm: [0008] 2f 42 0a b9 d1 3e b1 62
[ 1.915709] platform caam_sm: 192-bit clear key:
[ 1.921726] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 1.928791] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 1.935825] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 1.942816] platform caam_sm: 192-bit black key:
[ 1.948775] platform caam_sm: [0000] 0b e9 64 04 73 37 3e 2b
[ 1.955752] platform caam_sm: [0008] df 64 1e e1 69 b1 34 7e
[ 1.962667] platform caam_sm: [0016] 78 db dd 77 1d 03 fb 67
[ 1.969620] platform caam_sm: [0024] c9 c5 37 6b e3 f5 b3 08
[ 1.976566] platform caam_sm: 256-bit clear key:
[ 1.982454] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 1.989404] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 1.996321] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.003193] platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
[ 2.010066] platform caam_sm: 256-bit black key:
[ 2.015884] platform caam_sm: [0000] 48 b0 78 93 d7 e5 90 19
[ 2.022741] platform caam_sm: [0008] ba 96 c4 0c 21 d3 ef 59
[ 2.029599] platform caam_sm: [0016] 58 f4 4e e1 e7 99 48 2a
[ 2.036465] platform caam_sm: [0024] e6 10 bd 90 9c 5c 87 17
[ 2.043306] platform caam_sm: 64-bit unwritten blob:
[ 2.049458] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.056331] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.063158] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.069958] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.076728] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.083454] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.090157] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.096842] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.103485] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.110102] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.116688] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.123236] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.129757] platform caam_sm: 128-bit unwritten blob:
[ 2.135671] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.142198] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.148696] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.155175] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.161615] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.168040] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.174422] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.180776] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.187105] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.193397] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.199668] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.205904] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.212092] platform caam_sm: 196-bit unwritten blob:
[ 2.217711] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.223971] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.230241] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.236512] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.242773] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.249043] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.255313] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.261570] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.267839] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.274095] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.280363] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.286598] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.292783] platform caam_sm: 256-bit unwritten blob:
[ 2.298399] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.304657] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.310924] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.317195] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.323455] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.329722] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.335988] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.342246] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.348511] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.354769] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.361037] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.367273] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.373622] platform caam_sm: 64-bit black key in blob:
[ 2.379444] platform caam_sm: [0000] c1 da 29 fa bc 81 9d f4
[ 2.385716] platform caam_sm: [0008] 99 49 42 59 9b c4 f0 bb
[ 2.392006] platform caam_sm: [0016] db 61 76 93 5f 5f d2 59
[ 2.398334] platform caam_sm: [0024] ac 47 0b 6a ed 14 fa 9e
[ 2.404682] platform caam_sm: [0032] 67 5a 44 e7 81 47 1c 1d
[ 2.411082] platform caam_sm: [0040] 70 e3 23 da af 74 ed d9
[ 2.417502] platform caam_sm: [0048] 10 c4 2e 90 bc 8a 84 85
[ 2.423936] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.430404] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.436873] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.443335] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.449770] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.456167] platform caam_sm: 128-bit black key in blob:
[ 2.462248] platform caam_sm: [0000] b1 cd 20 e1 dc c2 dd fe
[ 2.468716] platform caam_sm: [0008] 59 cb e9 38 7f e8 94 ed
[ 2.475213] platform caam_sm: [0016] ce f5 79 45 dc 40 81 31
[ 2.481730] platform caam_sm: [0024] 92 c9 87 f1 5e 9e e9 f2
[ 2.488285] platform caam_sm: [0032] ef 25 b9 ee 50 7a 67 cb
[ 2.494862] platform caam_sm: [0040] f6 59 a6 72 93 b0 9e d1
[ 2.501476] platform caam_sm: [0048] 88 5d 94 66 4f 04 94 31
[ 2.508119] platform caam_sm: [0056] 6b 9b f9 24 16 a4 80 8d
[ 2.514785] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.521483] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.528182] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.534839] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.541464] platform caam_sm: 192-bit black key in blob:
[ 2.547749] platform caam_sm: [0000] 84 34 04 54 6b 1d 34 c2
[ 2.554382] platform caam_sm: [0008] 96 5f e4 93 10 41 e7 b3
[ 2.561021] platform caam_sm: [0016] de 8f ba 03 77 1a 94 ba
[ 2.567665] platform caam_sm: [0024] 12 37 b9 3e b7 64 9b 13
[ 2.574290] platform caam_sm: [0032] 0b c4 5d 9c e3 fd fa da
[ 2.580927] platform caam_sm: [0040] 6b 81 ee d2 d1 a9 66 1c
[ 2.587568] platform caam_sm: [0048] 0b ac d0 62 13 2d 69 28
[ 2.594222] platform caam_sm: [0056] 6d f8 f1 a8 17 eb 06 51
[ 2.600914] platform caam_sm: [0064] a3 f1 ea 69 4f 4e dc 0a
[ 2.607639] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.614381] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.621105] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.627794] platform caam_sm: 256-bit black key in blob:
[ 2.634123] platform caam_sm: [0000] 45 30 70 30 97 cc d7 a8
[ 2.640817] platform caam_sm: [0008] 13 1e a7 44 20 d9 33 89
[ 2.647511] platform caam_sm: [0016] 42 76 79 e0 fe 8b 25 96
[ 2.654197] platform caam_sm: [0024] e3 32 58 ee 82 5a c6 b4
[ 2.660892] platform caam_sm: [0032] 66 ca 32 5e e6 dd f9 b7
[ 2.667587] platform caam_sm: [0040] bb f8 22 3e 6c 39 24 80
[ 2.674280] platform caam_sm: [0048] 4f 78 79 3c 6e 95 a9 f0
[ 2.680974] platform caam_sm: [0056] fa 64 dd 48 fa e5 13 44
[ 2.687693] platform caam_sm: [0064] cb 95 e4 c3 f2 6d c3 bc
[ 2.694428] platform caam_sm: [0072] 8e 0a 4b da a4 e8 45 9c
[ 2.701202] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.707972] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.714825] platform caam_sm: restored 64-bit black key:
[ 2.721242] platform caam_sm: [0000] ef f8 b3 d7 48 50 69 d1
[ 2.728003] platform caam_sm: [0008] 40 a2 06 e5 99 b3 1d 7d
[ 2.734745] platform caam_sm: restored 128-bit black key:
[ 2.741237] platform caam_sm: [0000] 10 cb d4 26 90 10 a0 ba
[ 2.747999] platform caam_sm: [0008] 2f 42 0a b9 d1 3e b1 62
[ 2.754751] platform caam_sm: restored 192-bit black key:
[ 2.761257] platform caam_sm: [0000] 0b e9 64 04 73 37 3e 2b
[ 2.768033] platform caam_sm: [0008] df 64 1e e1 69 b1 34 7e
[ 2.774797] platform caam_sm: [0016] 5a ff 7c 91 ad 3c 88 db
[ 2.781608] platform caam_sm: [0024] 9d 14 96 6a 49 75 6f f8
[ 2.788437] platform caam_sm: restored 256-bit black key:
[ 2.794998] platform caam_sm: [0000] 48 b0 78 93 d7 e5 90 19
[ 2.801830] platform caam_sm: [0008] ba 96 c4 0c 21 d3 ef 59
[ 2.808672] platform caam_sm: [0016] 58 f4 4e e1 e7 99 48 2a
[ 2.815507] platform caam_sm: [0024] e6 10 bd 90 9c 5c 87 17
[ 2.822631] snvs-secvio 30370000.caam-snvs: violation handlers armed - checke
[ 2.831851] usbcore: registered new interface driver usbhid
[ 2.838717] usbhid: USB HID core driver
[ 2.844211] ad2802-adc 30610000.adc: Looking up vref-supply from device tree
[ 2.844760] ad2802-adc 30620000.adc: Looking up vref-supply from device tree
[ 2.846909] coresight-tmc 30086000.etr: TMC initialized
[ 2.853799] coresight-tmc 30084000.etf: TMC initialized
[ 2.860549] coresight-tpiu 30087000.tpiu: TPIU initialized
[ 2.867661] coresight-funnel 30083000.funnel: FUNNEL initialized
[ 2.875222] coresight-funnel 30041000.funnel: FUNNEL initialized
[ 2.882840] coresight-replicator replicator.1: REPLICATOR initialized
[ 2.891219] coresight-etm3x 3007c000.etm: ETM initialized
[ 2.898120] coresight-etm3x 3007d000.etm: ETM arch init failed
[ 2.905356] coresight-etm3x: probe of 3007d000.etm failed with error -22
[ 2.914661] i2c 0-000a: Driver sgtl5000 requests probe deferral
[ 2.927967] imx-sgtl5000 sound.19: ASoC: CODEC (null) not registered
[ 2.935869] imx-sgtl5000 sound.19: snd_soc_register_card failed (-517)
[ 2.943880] platform sound.19: Driver imx-sgtl5000 requests probe deferral
[ 2.952532] NET: Registered protocol family 26
[ 2.958686] TCP: cubic registered
[ 2.964157] NET: Registered protocol family 10
[ 2.971205] sit: IPv6 over IPv4 tunneling driver
[ 2.978250] NET: Registered protocol family 17
[ 2.984275] can: controller area network core (rev 20120528 abi 9)
[ 2.992156] NET: Registered protocol family 29
[ 2.998232] can: raw protocol (rev 20120528)
[ 3.004122] can: broadcast manager protocol (rev 20120528 t)
[ 3.011447] can: netlink gateway (rev 20130117) max_hops=1
[ 3.018812] Bluetooth: RFCOMM TTY layer initialized
[ 3.025340] Bluetooth: RFCOMM socket layer initialized
[ 3.032053] Bluetooth: RFCOMM ver 1.11
[ 3.037379] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.044269] Bluetooth: BNEP filters: protocol multicast
[ 3.051070] Bluetooth: BNEP socket layer initialized
[ 3.057631] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.065145] Bluetooth: HIDP socket layer initialized
[ 3.071724] 8021q: 802.1Q VLAN Support v1.8
[ 3.077547] Key type dns_resolver registered
[ 3.083526] Registering SWP/SWPB emulation handler
[ 3.093893] usb_otg2_vbus: disabling
[ 3.099059] regulator-dummy: disabling
[ 3.104559] usb_phy_gen_xceiv usbphy_nop3.13: Looking up vcc-supply from deve
[ 3.104596] platform usbphy_nop3.13: Driver usb_phy_gen_xceiv requests probel
[ 3.115613] sgtl5000 0-000a: sgtl5000 revision 0x11
[ 3.145843] 0-000a: 1200 mV normal
[ 3.150930] sgtl5000 0-000a: Using internal LDO instead of VDDD
[ 3.158462] sgtl5000 0-000a: Looking up VDDA-supply from device tree
[ 3.158532] sgtl5000 0-000a: Looking up VDDIO-supply from device tree
[ 3.158579] sgtl5000 0-000a: Looking up VDDD_LDO-supply from device tree
[ 3.158594] sgtl5000 0-000a: Looking up VDDD_LDO-supply property in node /sod
[ 3.169149] imx-sgtl5000 sound.19: sgtl5000 <-> 308a0000.sai mapping ok
[ 3.179330] usb_phy_gen_xceiv usbphy_nop3.13: Looking up vcc-supply from deve
[ 3.179369] platform usbphy_nop3.13: Driver usb_phy_gen_xceiv requests probel
[ 3.189348] UBI: default fastmap pool size: 200
[ 3.195570] UBI: default fastmap WL pool size: 25
[ 3.201889] UBI: attaching mtd3 to ubi0
[ 3.306330] UBI: attached by fastmap
[ 3.311528] UBI: fastmap pool size: 200
[ 3.316926] UBI: fastmap WL pool size: 25
[ 3.330505] UBI: attached mtd3 (name "ubi", size 507 MiB) to ubi0
[ 3.338245] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 3.346663] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 3.355006] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 3.363574] UBI: good PEBs: 4056, bad PEBs: 4, corrupted PEBs: 0
[ 3.371313] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 3.380212] UBI: max/mean erase counter: 9/3, WL threshold: 4096, image sequ0
[ 3.390301] UBI: available PEBs: 0, total reserved PEBs: 4056, PEBs reserved6
[ 3.403251] UBI: background thread "ubi_bgt0d" started, PID 127
[ 3.413509] rtc-ds1307 3-0068: setting system clock to 2016-06-15 19:19:06 U)
[ 3.465431] usb_phy_gen_xceiv usbphy_nop3.13: Looking up vcc-supply from deve
[ 3.471621] ALSA device list:
[ 3.476720] #0: imx7-colibri-sgtl5000
[ 3.482666] platform usbphy_nop3.13: Driver usb_phy_gen_xceiv requests probel
[ 3.506637] UBIFS: recovery needed
[ 3.607973] UBIFS: recovery deferred
[ 3.613619] UBIFS: mounted UBI device 0, volume 0, name "rootfs", R/O mode
[ 3.622508] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes
[ 3.635595] UBIFS: FS size: 503205888 bytes (479 MiB, 3963 LEBs), journal si)
[ 3.649744] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 3.657020] UBIFS: media format: w4/r0 (latest is w4/r0), UUID BCDC2293-AFA0l
[ 3.672749] VFS: Mounted root (ubifs filesystem) readonly on device 0:12.
[ 3.682790] devtmpfs: mounted
[ 3.688533] Freeing unused kernel memory: 284K (808aa000 - 808f1000)
[ 3.719064] random: nonblocking pool is initialized
[ 3.833945] systemd[1]: systemd 226 running in system mode. (+PAM -AUDIT -SE)
[ 3.859929] systemd[1]: Detected architecture arm.
[ 3.886272] systemd[1]: Set hostname to <colibri-imx7>.
[ 4.239371] systemd[1]: Created slice System Slice.
[ 4.265692] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 4.296941] systemd[1]: Listening on udev Control Socket.
[ 4.325438] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.356233] systemd[1]: Set up automount Arbitrary Executable File Formats F.
[ 4.395956] systemd[1]: Started Forward Password Requests to Wall Directory .
[ 4.425316] systemd[1]: Reached target Swap.
[ 4.445648] systemd[1]: Created slice system-getty.slice.
[ 4.475489] systemd[1]: Started Dispatch Password Requests to Console Direct.
[ 4.505432] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.535312] systemd[1]: Reached target Paths.
[ 4.555645] systemd[1]: Listening on networkd rtnetlink socket.
[ 4.585501] systemd[1]: Listening on Journal Socket.
[ 4.607463] systemd[1]: Starting Setup Virtual Console...
[ 4.622001] systemd[1]: Mounting Temporary Directory...
[ 4.641999] systemd[1]: Mounting Debug File System...
[ 4.689325] systemd[1]: Starting Journal Service...
[ 4.718197] systemd[1]: Starting Create list of required static device nodes.
[ 4.769518] systemd[1]: Starting Load Kernel Modules...
[ 4.789973] systemd[1]: Starting (null)...
[ 4.827411] systemd[1]: Starting File System Check on Root Device...
[ 4.875596] systemd[1]: Listening on udev Kernel Socket.
[ 4.909428] systemd[1]: Created slice User and Session Slice.
[ 4.945466] systemd[1]: Reached target Slices.
[ 4.970888] systemd[1]: Mounted Debug File System.
[ 5.005608] systemd[1]: Mounted Temporary Directory.
[ 5.028996] systemd[1]: Started Setup Virtual Console.
[ 5.067116] systemd[1]: Started Create list of required static device nodes .
[ 5.116216] systemd[1]: Started Load Kernel Modules.
[ 5.136913] systemd[1]: Started (null).
[ 5.156242] systemd[1]: Started File System Check on Root Device.
[ 5.212321] systemd[1]: Started Journal Service.
[ 5.370224] UBIFS: completing deferred recovery
[ 5.589997] UBIFS: background thread "ubifs_bgt0_0" started, PID 168
[ 5.609266] UBIFS: deferred recovery completed
[ 5.933780] systemd-journald[146]: Received request to flush runtime journal1
[ 5.976499] systemd-journald[146]: File /var/log/journal/ff6005d0ff69447388e.
[ 7.537771] evbug: Connected device: input0 (AD7879 Touchscreen at 0-002c/in)
[ 9.453331] using random self ethernet address
[ 9.459759] using random host ethernet address
[ 10.545309] fec 30be0000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ)
[ 10.626825] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.545793] libphy: 30be0000.etherne:00 - Link is Up - 100/Full
[ 13.551750] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
And lsusb gives:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I have tried this with three separate keyboards, (microsoft wired microsoft wireless, and an apple keyboard.)
There seems to be no recognition of any of them.
