I have:
- Aster carrier board (V1.1B)
- Colibri iMX8 DualX 1GB V1.0D
- Capacitive Touch Display 7" Parallel V1.0B.
- torizon-core-docker-colibri-imx8x-Tezi_5.7.0+build.17.tar
- host: Windows 10pro with docker, VSCode and torizoncore-builder
If I apply the device overlays (fdt_overlays=colibri-imx8x_parallel-rgb_overlay.dtbo colibri-imx8x_atmel-mxt-connector_overlay.dtbo display-lt161010_overlay.dtbo) on the image directly on the device, the USB Host ports work without problem, but if I put the overlays in a tcbuild.yaml configuration file to build a production image, the USB Host ports don’t work, power is not available to the connected devices.
I tried several overlay combinations but when I add colibri-imx8x_atmel-mxt-connector_overlay.dtbo or colibri-imx8x_atmel-mxt-adapter_overlay.dtbo, the USB Host ports don’t work.
With my image and atmel_mxt overlay, the USB Host does not work, dmesg | grep -i USB:
[ 0.116342] usbcore: registered new interface driver usbfs
[ 0.116387] usbcore: registered new interface driver hub
[ 0.116422] usbcore: registered new device driver usb
[ 1.754294] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.755719] usbcore: registered new interface driver usb-storage
[ 1.755823] usbcore: registered new interface driver usbserial_generic
[ 1.755846] usbserial: USB Serial support registered for generic
[ 1.849940] usbcore: registered new interface driver usbhid
[ 1.849944] usbhid: USB HID core driver
[ 1.875551] usbcore: registered new interface driver snd-usb-audio
[ 1.990565] usb3503 16-0008: switched to HUB mode
[ 1.990579] usb3503 16-0008: usb3503_probe: probed in hub mode
With my image without atmel_mxt overlay, the USB Host works, dmesg | grep -i USB:
[ 0.119189] usbcore: registered new interface driver usbfs
[ 0.119235] usbcore: registered new interface driver hub
[ 0.119267] usbcore: registered new device driver usb
[ 1.763215] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.764763] usbcore: registered new interface driver usb-storage
[ 1.764860] usbcore: registered new interface driver usbserial_generic
[ 1.764883] usbserial: USB Serial support registered for generic
[ 1.872752] usbcore: registered new interface driver usbhid
[ 1.872755] usbhid: USB HID core driver
[ 1.905692] usbcore: registered new interface driver snd-usb-audio
[ 1.960865] mxs_phy 5b100000.usbphy: 5b100000.usbphy supply phy-3p0 not found, using dummy regulator
[ 1.974194] regulator-usbh-vbus GPIO handle specifies active low - ignored
[ 1.974649] usb_phy_generic bus@5b000000:usb3-phy: bus@5b000000:usb3-phy supply vcc not found, using dummy regulator
[ 2.014912] usb3503 16-0008: switched to HUB mode
[ 2.014925] usb3503 16-0008: usb3503_probe: probed in hub mode
[ 2.049168] xhci-cdns3: new USB bus registered, assigned bus number 1
[ 2.051311] hub 1-0:1.0: USB hub found
[ 2.051663] xhci-cdns3: new USB bus registered, assigned bus number 2
[ 2.051677] xhci-cdns3: Host supports USB 3.0 SuperSpeed
[ 2.051747] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.052299] hub 2-0:1.0: USB hub found
[ 2.211863] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 3
[ 2.232220] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 2.233139] hub 3-0:1.0: USB hub found
[ 2.532324] usb 1-1: new high-speed USB device number 2 using cdns-usb3
[ 2.715172] hub 1-1:1.0: USB hub found
[ 3.032323] usb 1-1.2: new full-speed USB device number 3 using cdns-usb3
[ 8.664423] usbcore: registered new interface driver ftdi_sio
[ 8.664478] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 8.664695] ftdi_sio 1-1.2:1.0: FTDI USB Serial Device converter detected
[ 8.664837] usb 1-1.2: Detected FT-X
[ 8.680383] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
Recap:
- overlay applied from command line, everything is ok
- image without atmel overlay, screen not working, USB fine
- image with atmel overlay, screen ok, USB not working
What am I doing wrong?
giulio
