USB host functionality on 2ND USB PORT IN VF61
How to enable 2nd usb port to act as usb host to connect the usb2serial adapter
Inside registry under
HKLM\Drivers\Builtin\HCD_HSH2 rename DLL from _hcd_hsh1.dll to hcd_hsh1.dll
and under
HKLM\Drivers\Builtin\USBOTG rename dll from otg_vybrid.dll to _otg_vybrid.dll
Save the registry and reboot.
AS SPECIFIED WE HAVE DONE BELOW CHANGES IN REGISTRY
HKLM\Drivers\Builtin\HCD_HSH2 rename DLL from _hcd_hsh1.dll to hcd_hsh1.dll and under HKLM\Drivers\Builtin\USBOTG rename dll from otg_vybrid.dll to _otg_vybrid.dll
AND SAVED THE REGISTRY AND REBOOTED THE SYSTEM
bUT THE 2ND USB PORT IS NOT RECOGNIZING THE USB PEN DRIVE.
THE USB_ID is not low to enable the TPS2042BDRB PWREN# IN
CAN WE MAKE THE SODIMM_135 pin low from our application to enable the power to USB port
AS SPECIFIED WE HAVE DONE BELOW CHANGES IN REGISTRY HKLM\Drivers\Builtin\HCD_HSH2 rename DLL from _hcd_hsh1.dll to hcd_hsh1.dll and under HKLM\Drivers\Builtin\USBOTG rename dll from otg_vybrid.dll to _otg_vybrid.dll AND SAVED THE REGISTRY AND REBOOTED THE SYSTEM
bUT THE 2ND USB PORT IS NOT RECOGNIZING THE USB PEN DRIVE. THE USB_ID is not low to enable the TPS2042BDRB PWREN# IN
You can use our gpio library to set the value of that pin. GPIO lib can be found on our developers site.
