I have a USB device that is not showing up as a tty device. Typically when a USB is connected it is mounted as ttyUSB*. When this device is connected the kernal message bugger output is:
[84904.951061] usb 1-1.2: new high-speed USB device number 10 using xhci-hcd
Why do you assume that the specified device should appear as a USB to serial interface (e.g., ttyUSB)? The documentation from the provided link doesn’t mention this. It instead highlights the need to install custom software to communicate with the device. For Linux, the manufacturer advises installing the Universal Library API from GitHub (GitHub - mccdaq/uldaq: MCC Universal Library for Linux). This needs to be integrated into your Linux system. One more Linux related link from the device manufacturer - Universal Library for Linux® - Digilent Reference
Took me a while to hop back on this. Thanks for all the information.
I have installed uldaq and it’s associated dependencies in the dockerfile. These appears to allow for a basic connection to the device where I can request information from it. However I still can’t establish a connection with the device.
When trying to connect, I am met with an “insufficient permissions to access this device” error. This leads me to believe that I still need to expose either a “device” or “volume” to access the USB device.
Have you already tried this? A quick and easy check to see if this is the case is to bind-mount all of /dev and then run the container with --privileged. This would give you a container with full access. If this works then it was a permission issue. In which case you can scale back the permissions to only give access to what you need.
