I have a multi tech mdot plugged into the USB port of the colibri evaluation board. When running a read/write situation to the USB port (code is attached) it seems to run for about 2 minutes untill I get an error with the USB port which causes the USB to restart and breaks the code that is running. I have attached a photo of the error. Can I please get some help with how to stop this from happening ?
Michaellink text
