USB Camera Support
Hello @henrique.tx,
I have already shared the command that i have used commands are available in above chat and also all other commands and descriptions are there
regards,
Ravi Vanand
hello @henrique.tx ,
All the command, description and which documentation i have read this all information i have shared in earlier chat
Ravi Vanand
Hii @henrique.tx ,
I have followed the below command and get the below result
  • WARNING **
    THIS DEVICE IS IN ENGINEERING MODE
Check for more info:
torizon@verdin-imx8mp-15132884:~$ ls
Dockerfile digital_io_test.sh imx8mp-verdin-wifi-atdm.dtb test
Downloads docker-compose.yml index.html test.wav
adv7180.ko gstreamer-docker media-ctl-setup
dev2 home setup
torizon@verdin-imx8mp-15132884:~$ ls /dev/video*
/dev/video0 /dev/video1 /dev/video2 /dev/video3 /dev/video4 /dev/video5
torizon@verdin-imx8mp-15132884:~$ v4l2-ctl --list-formats-ext -d /dev/video0
Failed to open /dev/video0: Device or resource busy
torizon@verdin-imx8mp-15132884:~$ v4l2-ctl --list-formats-ext -d /dev/video4
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
    [0]: 'YUYV' (YUYV 4:2:2)
                    Interval: Discrete 0.033s (30.000 fps)
                    Interval: Discrete 0.042s (24.000 fps)
                    Interval: Discrete 0.050s (20.000 fps)
                    Interval: Discrete 0.067s (15.000 fps)
                    Interval: Discrete 0.100s (10.000 fps)
                    Interval: Discrete 0.133s (7.500 fps)
                    Interval: Discrete 0.200s (5.000 fps)
            Size: Discrete 1792x1008
            Size: Discrete 1920x1080
                    Interval: Discrete 0.500s (2.000 fps)
            Size: Discrete 1600x1200
            Size: Discrete 2048x1536
            Size: Discrete 2592x1944
    [1]: 'MJPG' (Motion-JPEG, compressed)
                    Interval: Discrete 0.017s (60.000 fps)
torizon@verdin-imx8mp-15132884:~$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=1280,height=720,pixelformat=1 --stream-mmap --stream-to=image.jpg --stream-count=1
torizon@verdin-imx8mp-15132884:~$ v4l2-ctl -d /dev/video4 --set-fmt-video=width=1280,height=720,pixelformat=1 --stream-mmap --stream-to=image.jpg --stream-count=1
Dockerfile digital_io_test.sh image.jpg setup
Downloads docker-compose.yml imx8mp-verdin-wifi-atdm.dtb test
adv7180.ko gstreamer-docker index.html test.wav
dev2 home media-ctl-setup
torizon@verdin-imx8mp-15132884:~$ ffmpeg -f v4l2 -framerate 30 -video_size 1280x720 -i /dev/video0 -t 10 output_video.mp4
-sh: ffmpeg: command not found
torizon@verdin-imx8mp-15132884:~$ ffmpeg -f v4l2 -framerate 30 -video_size 1280x720 -i /dev/video4 -t 10 output_video.mp4
torizon@verdin-imx8mp-15132884:~$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=1280,height=720,pixelformat=1 --stream-mmap --stream-to=output_video.raw --stream-count=300
torizon@verdin-imx8mp-15132884:~$ v4l2-ctl -d /dev/video4 --set-fmt-video=width=1280,height=720,pixelformat=1 --stream-mmap --stream-to=output_video.raw --stream-count=300
<<<<<<<<<<<<<<<<<<<<<<<<<< 24.61 fps
<<<<<<<<<<<<<<<<<<<<<<< 23.81 fps
<<<<<<<<<<<<<<<<< 21.64 fps
<<<<<<<<<<<<<<<<<< 20.51 fps
<<<<<<<<<<<<<<<<< 19.86 fps
<<<<<<<<<<<<<<<<< 19.42 fps
<<<<<<<<<<<<<<<<< 19.11 fps
<<<<<<<<<<<<<<<<<< 18.86 fps
<<<<<<<<<<<<<<<<< 18.68 fps
<<<<<<<<<<<<<<<<< 18.54 fps
<<<<<<<<<<<<<<<<< 18.42 fps
<<<<<<<<<<<<<<<<< 18.32 fps
<<<<<<<<<<<<<<<<<< 18.23 fps
<<<<<<<<<<<<<<<<< 17.97 fps
<<<<<<<<<<<<<<<<< 17.42 fps
<<<<<<<<<<<<<<<<< 17.21 fps
Dockerfile digital_io_test.sh image.jpg output_video.raw
Downloads docker-compose.yml imx8mp-verdin-wifi-atdm.dtb setup
dev2 home media-ctl-setup test.wav
torizon@verdin-imx8mp-15132884:~$ ^C
torizon@verdin-imx8mp-15132884:~$ modetest | grep connected
-sh: modetest: command not found
torizon@verdin-imx8mp-15132884:~$ tdx-info
Please, run as root.
torizon@verdin-imx8mp-15132884:~$ sudo tdx-info
Password:
Software summary
Bootloader: U-Boot
Kernel version: 5.15.148-6.7.0-devel+git.8c5c2dcbf6ba #1-TorizonCore SMP PREEMPT Wed Aug 21 06:38:22 UTC 2024
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/ace22d76c2ae8ec7bd113140f6f8cf2db721ecba378b6d3523075386ccdbda50/0
Distro name: NAME=“TorizonCore”
Distro version: VERSION_ID=6.7.0-devel-20240821064044-build.0
Distro variant: VARIANT=“Docker”
Hostname: verdin-imx8mp-15132884
Hardware info
HW model: Toradex Verdin iMX8M Plus WB on ATDM Board
Toradex version: 0058 V1.1A
Serial number: 15132884
Processor arch: aarch64
torizon@verdin-imx8mp-15132884:~$ weston-simple-image image.jpg
-sh: weston-simple-image: command not found
torizon@verdin-imx8mp-15132884:~$ scp torizon@verdin-imx8mp-15132884:/home/torizon/image.jpg /local/directory/
The authenticity of host ‘verdin-imx8mp-15132884 (fe80::2bfb:4ea6:321:d42c%ethernet0)’ can’t be established.
ED25519 key fingerprint is SHA256:C50T/jNy7Aomvvn5D9ImooCOEPhKKOofncT3H9C2y1E.
This host key is known by the following other names/addresses:
~/.ssh/known_hosts:1: 192.168.0.137
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Warning: Permanently added ‘verdin-imx8mp-15132884’ (ED25519) to the list of known hosts.
torizon@verdin-imx8mp-15132884’s password:
/local/directory/: No such file or directory
torizon@verdin-imx8mp-15132884:~$ systemctl status weston
Unit weston.service could not be found.
torizon@verdin-imx8mp-15132884:~$ sudo systemctl status weston
torizon@verdin-imx8mp-15132884:~$ weston --backend=drm-backend.so
-sh: weston: command not found
Ravi Vanand
