USB-C with video
Is possible on Toradex platform create device with USB-C and connect it display ?
Is it doable?
Generally speaking, yes, it is possible. However, if you desire more specific information, you need to clarify which USB-C video mode you intend to use. Many Toradex modules come with a native HDMI interface, allowing you to use the USB-C HDMI Alt Mode to transmit HDMI signals over USB-C. Additionally, you could integrate an extra IC into your carrier board to convert other video interfaces supported by the Toradex module (such as DSI) into either HDMI or DisplayPort signals, which can then be transmitted over USB-C.
Hello @MariusM ,
Did @alex.tx 's answer solve your doubt? If so, could you please mark his answer as solution?
Josep
