Urgent - I2C Warning
Why do i get warning message as shown below when try to communicate with I2C.
I2C Warning: .\src\i2c_vyb.c, 148: Start failed
Dear @Sarika
As mentioned in my other comment, we need more information to help you. I don’t know what library version you are using, neither what you i2c hardware setup looks like, nor what code you execute.
Without that information I can only tell you that there was an error while generating the start condition - I don’t think this is of any help to you.
Regards, Andy
I2C library version 2.3
Not modified any Hardware setup…
Trying to communicate “I2C1” as given in the below.
I2c_Init()
I2c_Open
I2c_Write() or I2c_Read()
I2c_Close()
I2c_Deinit()
Usually this happens when there are no pull-ups on the I2C lines. What kind of board are you using?
alt text
Getting same warning message when i run I2C Demo Solution given by Toradex without any modification done in the source code.
alt text
This does not answer my question. What carrier board are you using? Do you have pull-ups on the I2C lines?
