UpdateTool Error on Colibri T20
I have a running CE7 system based on BSP V1.3 on a Colibri T20. The flashdisk is splitted into 2 partitions mounted as flashdisk and flashdisk2.
I created a backup of this system with the UpdateTool V6.0.1 as described here without any errors.
But programming of the created backup on a system based on BSP 1.4 failed with the following UpdateTool error message:
“UDLDoUpdate: Unknown error: 1”
The UpdateTool was started as described with the additional parameter “/nandecc rs4”
@Toni: Thanks for the report. Could you please enable debug output on serial port and send us the output you get there. How to enable debug output: http://developer.toradex.com/knowledge-base/enable-the-debug-messages
