I have used the Update Tool in the latest WinCE6 image 1.5 to update the bootloader and after that the module was unbootable.
@h.steff
Could you please completely erase the flash and reprogram the latest image as per our documentation:
https://developer.toradex.com/knowledge-base/vfxx-recovery-mode
https://developer.toradex.com/knowledge-base/colibri-vf50-vf61-wince-bring-up
https://developer.toradex.com/knowledge-base/production-programming-for-colibri-vfxx-modules
Please use the latest updateTool which is coming with release image, please don’t use OS inbuilt / running update tool. We are always recommending to use newest update tool which will be in the release package.
Also, refer this : https://www.toradex.com/community/questions/18869/is-there-a-way-to-clone-with-update-tool-730-20.html
Let us know if you are facing the issue after above procedure.
