Andre
1
I needed to fit my device tree file I copied the new DTB file to my sdcard and stop the boot process.
Enter the following commands
- run setupdate
- run prepare_ubi
- run update_fdt
It looks good, but after reboot the uboot can’t load the kernel. I get the following message:
- Read 0 bytes from volume kernel to 81000000
- Read 0 bytes from volume dtb to 82000000
- Bad Linux ARM zImage magic!
Why it isn’t possible to update only the FDT?
The steps to properly prepare an SD card for this method are outlined here: Flashing Embedded Linux to Vybrid Modules . Also for reference the instructions on updating an image:Build U-Boot and Linux Kernel from Source Code | Toradex Developer Center .
Please confirm if these steps work for you.
FDT located at UBI partition named “dtb”
It’s accessible from Linux and can be updated using
ubiupdatevol <dev_name> <dtb file>
Usually, for DTB the dev_name is /dev/ubi0_1
You can check it by ubinfo /dev/ubi command
FDT can be also updated using U-Boot
# ubi part ubi
# fatload mmc 0:1 ${fdt_addr_r} <fdt_file>
# ubi write ${loadaddr} m4firmware <filesize>
When you do FDT debugging you can update a bootscript to load Device Tree directly from MMC card.
Please see ubiboot and sdboot environment variables
You are welcome. Thanks for the feedback.
