Update Bootloader iMX6
I try to update the Bootloader, i tested:
  1. Over the Commandline with “\Windows\update.exe /u spl,raw,\eboot.spl”, that say "Update Failed."
  2. Over the ToradexCeLibraries_V2.0-20170524 with follow steps, Upd_Restore() return 0
  3. _updHandle = Upd_Init();
  4. Upd_SetConfigString(_updHandle, “filename”, “\eboot.spl”, StoreVolatile);
  5. Upd_SetConfigString(_updHandle, “sections”, “spl”, StoreVolatile);
  6. Upd_SetConfigString(_updHandle, “format”, “raw”, StoreVolatile);
  7. int ReturnValue = Upd_Restore(_updHandle);
  8. Manual over the update.exe gui (type “i.MX6 SPL bootloader image”) → that woks
For SPL loader the section is “bootloader” and format is “SPL”, so replacing “spl” with “bootloader” and “raw” with “spl” in your samples should work.
This works, thanks
Upd_SetConfigString(_updHandle, “sections”, “bootloader”, StoreVolatile);
Upd_SetConfigString(_updHandle, “format”, “spl”, StoreVolatile);
