Unattended update after plug in USB memory
My platform: iris+imx8x
I found some interesting differences between Linux image 5.1 vs 6.3
In Linux 5.1 I add to /etc/udev/scripts/mount.sh few magic lines:
(if secret_update.tar exist , extract and run)
if [ -f "/media/$name/secret_update.tar" ]; then
  export DISPLAY=:0.0; xterm -T "UPDATE" -n "UPDATE" -fg white -bg blue -geometry 120x31+100+350   -e "cd /tmp; tar -xvf /media/$name/secret_update.tar; cd update-system; ./update.sh; sleep 10"
fi
And it works ! This method has always worked since BSP 2.0
In linux BSP 6.3 /etc/udev/scripts/mount.sh works differently
device is mounted after mount.sh finished
I can’t check in mount.sh if the file exists “/media/$name/secret_update.tar”
how to improve it?
Were add my scripts ? How to run a script when flash-drive is mounted?
Hello @MariusM ,
One option could be to add an additional rule in /etc/udev/rules.d/automount.rules that runs an “after_mount.sh” script.
This script can be located in /etc/udev/scripts.
I did a simple test adding the following rule at the end of automount.rules,
SUBSYSTEM=="block", ACTION=="change" RUN+="/etc/udev/scripts/after_mount.sh"
after_mount.sh checks for a file in /media/sda and prints OK if the file is found.
#!/bin/sh
# Called from udev
if [ -f "/media/sda/ok" ]; then
   echo "OK" >/dev/kmsg
fi
Hope that it helps.
Josep
Thank you for your help !
Works !
Toradex means great support
