Unable to run weston container in Torizon Core 6.4 /6.5
Im facing issue in running weston container in torizon-core 6.4/6.5 below is the command I used for running the container in torizon core 6.2, I used the same for 6.4/6.5. Is there any change to be done?
docker run -e ACCEPT_FSL_EULA=1 -d --rm --name=weston --net=host --cap-add CAP_SYS_TTY_CONFIG -v /dev:/dev -v /tmp:/tmp -v /run/udev/:/run/udev/ --device-cgroup-rule=‘c 4:* rmw’ --device-cgroup-rule=‘c 13:* rmw’ --device-cgroup-rule=‘c 199:* rmw’ --device-cgroup-rule=‘c 226:* rmw’ torizon/weston-vivante:$CT_TAG_WESTON_VIVANTE --developer weston-launch --tty=/dev/tty7 --user=torizon
Hi @sapthagiri,
Can you please share complete hardware detail and output of tdx-info in order to understand complete setup you are using.
Additionally please run without -d flag and see if you get relevant error or log to further understand issue.
Ritesh Kumar
below is the system info:
Software summary
Bootloader: U-Boot
Kernel version: 5.15.129-6.4.0+git.67c3153d20ff #1-TorizonCore SMP PREEMPT Wed Sep 27 12:30:36 UTC 2023
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/460c0c1dde52ce6a4fd14e6ff7399ad1c879175a9ffa047acbb97523d9376591/0
Distro name: NAME=“TorizonCore”
Distro version: VERSION_ID=6.4.0-build.5
Hostname: verdin-imx8mp-06849207
Hardware info
HW model: Toradex Verdin iMX8M Plus on Verdin Development Board
Toradex version: 0061 V1.0B
Serial number: 06849207
Processor arch: aarch64
I ran the command without -d and below message was prompted
/usr/bin/entry.sh: unrecognized option '–user=torizon
I couldn’t see the container running with docker ps command the same goes for command with -d
Please try with below
docker run -e ACCEPT_FSL_EULA=1 -d --rm --name=weston --net=host --cap-add CAP_SYS_TTY_CONFIG \
             -v /dev:/dev -v /tmp:/tmp -v /run/udev/:/run/udev/ \
             --device-cgroup-rule='c 4:* rmw' --device-cgroup-rule='c 13:* rmw' \
             --device-cgroup-rule='c 199:* rmw' --device-cgroup-rule='c 226:* rmw' \
             torizon/weston-vivante:$CT_TAG_WESTON_VIVANTE --developer --tty=/dev/tty7
Ritesh Kumar
Its working thanks a lot
